Question about Tivoli Model Three Clock Radio
CLOCK NOT WORKING
BATTERY IS OK BUTTON AT REAR TO ADVANCE CLOCK HANDS NOT WORKING. LIGHT IN CLOCK IS WORKING.pOWER SUPPLY IS OK
WHAT IS WRONG WITH CLOCK
  • reed_shirley May 12, 2009
    I am having simalar problems. my radio give a beep then the hands begin to advance. this only happens when I insert a battery in , if it is plugged into outlet this does not happen, i can no longer set the clock as the button on back is not functioning . the radio works fine
    Problem Solver:
  • 5 Answers
Time to sell it on ebay!
Posted on Jun 04, 2009
HOW DO YOU SET THE CLOCK? I CAN'T GET THE OVENS TO WORK
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Apr 30, 2015 | Ovens Ovens
Haotion 125 bad earth lights working incorrectly
intermintant loss of power to headlights clock air conditioning 2001 toyota avalon ! solution....new alternator and new battery fitted.
Oct 04, 2012 | Cars & Trucks
Team sports america scoreboard clock has no display after a brief power outage
Their is a 3.7v button battery inside,it will cause the display to fail when it is dead,it was discharged after your power went out.Replace the battery and it will work again,I have done this.
Jul 14, 2012 | Audio Players & Recorders
After replacing the batteries in both the clock and the outside unit, everything is perfect except I cannot get the clock to allow me to change to Central Standard Time. Have followed instructions...
Hello
After replacing the batteries do the following to set the time.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Aug 25, 2011 | La Crosse Radio Controlled Atomic Clock
Second hand has stopped working. Stopped on # 11. Have tried new battery and resetting clock by reinserting battery. Sometimes second hand will work for a limited time. Clock keeps good time with hour and...
Hello
Just setup the clock once again by replacing the battery and check. If this also does not help you, the the press fitting of the second is loose. you have to open it to make it pressed firm.
OK.
Jul 03, 2011 | La Crosse Radio Controlled Atomic Clock
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
May 18, 2010 | Seiko Mantel Clock
My Barolo atomic wall clock (with hands) stopped working (I think the battery died). I replaced the battery, and now the hands just keep going around without stopping. I have removed & replaced the...
Try to move the clock to a different place. Atomic clocks work by receiving a radio signal. If it has no reception, it may do that. However, I would suspect that no reception would lead to it not setting at all(at least based on the ones I've seen) and it may be something wrong with it (i.e. having difficulty detecting where it's hands are) Good luck.
Jan 03, 2010 | Kitchen Appliances - Others
Tivoli model three clock problems
SELL! SELL! SELL! Yup the clock has bit the dust sell er and cut your losses.
May 12, 2009 | Tivoli Model Three Clock Radio
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Tivoli Model Three Clock Radio Logo
626 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
