I have an rca antenna model ant110. & i don't get where/how to connect the uhf part [round metal piece] the picture on line is not clear & we do not have the box it came in. thank you
  • 41 Answers
You will need a Vhf/uhf combiner to attach to the antenna to new TV's. Check with your local TV repair shop, they should be readily available.
Posted on Dec 18, 2008
I have a JVC LT39E330 FLAT SCREEN T.V. IT WAS PLAYNG JUST FINE WHEN IT WENT ALL STATICY AND LINES ALL THROUGH THE PICTURE. DO YOU HAVE ANY IDEA WHAT OT MAY BE?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 17, 2015 | JVC Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
RCA HDTV antenna is it Ok on a non HDTV
Yes, this antenna will receive VHF and UHF signals. If you install it properly outside and point it towards your local transmitters, it will work nicely (use tvfool.com for the directions to your transmitters). The "HD" label is something of a marketing gimmick; the tuner on the TV will pull in the signal and interpret ito display on your TV.
However, make sure that you have an ATSC tuner for your TV. Only a few low power NTSC stations are still broadcasting.
I hope this helps.
Apr 15, 2013 | RCA Televison & Video
The tv isvhf and uhf in otherwords no picture how to receive digital on anolog system or get a pic on my tv anologly
Only one av plug in maybe plug in your analog TV scanner into av slot I have one to wondering if antenna plug in none but av one slot maybe antenna into from analog digital stream or RCA analog might give me antenna to directly off my RCA digital box
Sep 16, 2012 | Vector Vec135 Tough Brite Storm Tracker...
Red light stays on no sound. rca cable grnd, must be connected?
What do you mean the RCA cables are'nt grounded? All RCA cable have a ground. What kind are you using? The round metal at the end of the RCA cable is the ground. The silver or outside of the line input on the amp is the ground for the RCA cables. Anyway, that would'nt stop your amp from coming on. I suggest you take a piece of wire and ground it to the amp and touch the metal piece on the RCA cable and see if you get sound. Even if the RCA cable is'nt grounded you would get some type of sound coming out of the amp maybe. If you do it will sound like it's cominf thru a long tunnel, like a reverb effect. I have never heard of an RCA cable not having a ground. ARE you sure you have RCA cables? Let me know and send me a pic if you can of the input of the amp so I can see how you have it hooked up.
Jan 07, 2009 | Kenwood KAC-9152D Car Audio Amplifier
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Rca
This is typically caused by poor ground connections either at the cable input or inside the tuner itself. Check all external cable connections for good grounds. If those are good, then the tuner needs to be examined carefully for poor solder connections at the grounds.
Dan
Nov 28, 2008 | Televison & Video
RCA p52921
You will need to connect your antenna and do an auto search. When the search is over you might have to choose the broadcast option over the cable selection. That might bring in the picture.
Jul 21, 2008 | RCA P52921 52" Rear Projection Television
Antenna on RCA F27615
If this set has Guide Plus in the menus then set it up. Choose ant or cable, in menus, and No for cable box and no for DVD and no for vcr and finish. If you choose yes for a cable box then it locks the channel to 3 to match your cable box.
Mar 24, 2008 | RCA F27615 27" TV
Open Questions:
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
