My washer wont drain - Washing Machines
  • yelofela Dec 17, 2008
    IVE GOT A KITCEN AID TOP LOAD WASHER IT STOPS MID CYCLE AND THATS THAT. FULL OF WATER AND ALL.
    Scholar:
  • 33 Answers
Dear Customer,
please rate this solution if it meets ur needs,else choose fixya..
please perform the following checks
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
  • please rate this solution if it meets ur needs,else choose fixya..Thank you..
    Posted on Dec 17, 2008
    My washer has slow drain and won't spin out completely. What might be the problem?
    Repairing a Washer That Won't Drain or Spin ' ThriftyFun
    www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
    Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
    my washer won't spin and empty? ' Yahoo Answers
    https://answers.yahoo.com/question/index?qid...
    Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
    Mar 21, 2013
    Clothes washer won't spin clothes to drain water out?
    Jun 11, 2008
    More results from answers.yahoo.com
    Why won't my washer spin or drain? - Kenmore 110 Series ...
    https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
    iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
    My washing machine won't drain - LaundryDoc.com
    www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
    If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
    Jan 05, 2016 | Washing Machines
    Why wont my washer drain drain
    Probably the pump is stopped up or gone bad . Replace
    Nov 20, 2014 | Washing Machines
    Kenmore elite he3t front loading washer wont drain
    Here is one of the most common reasons a front load washer will not drain, you can try to fix this yourself following this guide:
    Front Load Washer Wont Drain
    Jan 10, 2014 | Washing Machines
    The washer drum wont spin.
    If your washer does not drain you need to check this parts.
    1. Inspect the drain hose for kinks
    2. Test the timer control
    3. Test the lid switch(some models)
    4. Inspect the water pump
    5. Inspect the drive belt(belt drive only)
    6. Inspect the motor coupler
    Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
    My washer wont drain the water....It spins but wont drain
    This must be a brand new Kenmore 20.6 cu. ft top freezer refrigerator. I have serviced over 10,000 refrigerators and freezers. Never once did i see one that had a washer, let alone one that spins but wont drain. Maybe you should try the washer forum.
    Mar 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
    G.e. washer wont **** out rhe water
    I did all the tips to check the pump. Took washer a part and no luck. I was ready to haul it to the dump. As a last resort I put drain cleaner (dollar tree brand) in the tub and ran the washer on hot. After the cycle I lowered the hose inot a bucket and turned the washer on Drain. I heard a pop and the pump was free. Works like a champ now.
    Mar 13, 2010 | GE WBSR3140DW Top Load Washer
    Washer stops after aggatating and wont drain
    My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
    Jun 10, 2009 | Whirlpool Washing Machines
    MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
    OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
    May 06, 2009 | LG WM2277H Front Load Washer
    Water just drains, wont fill up washer
    the top of the hose must be higher than the water level in the washer for proper operation
    or
    the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
    Apr 17, 2009 | Washing Machines
    Washer wont spin
    is it draining ok or does it m ake any noises as if trying to spin?
    Mar 05, 2008 | Zanussi F1045W Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
