Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Water on floor under side by side gallery refrigerator
Our Ice maker is not leaking, but water is under refer at times.
  • tommy segers Nov 13, 2011
    i have a side by side glhs66efsb3 leakin in floor on frezzer side when i turn water supply back on it takes 5 minutes to puddle in floor checked water lines were ok ice maker works ok dose this unit have a tank for chilled water if so were is it located thanks
  • 86 Answers
Hi there check wether or not the boil away tray underneath the fridge has an element if it does check to see if it is open circuit ,if so replace element.Hope that helps.
Posted on Dec 18, 2008
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Every time we turn on our ice maker it leaks on the floor and ice bulids up on the floor of the freezer. it makes ice fine and the water dispenser works fine. we have replaced the water line thinking...
Most times the leak is caused by a defective dual water control valve but in this case it is obviously not the problem. Make sure your refrigerator is level front back and sides. If the problem is not cause by being out of level I want you to look for cracks in the W10190929 Ice Maker Mold and Heater assembly. Also where the water pours into slot 22 below
Anything is possible so you may need remove the ice maker so you can examine it closely if impossible to see while inside the freezer. Complete 4317943 Ice Maker Assembly or 2188542 Dual Water Control Valve Let me know if you have questions, Thanks Sea Breeze
Nov 17, 2012 | Whirlpool 19.8 cu. ft. Side-by-Side...
My matag model # mzd2766ge side by side has been leaking water on the floor. This happens only sometimes but by the time we notice its a big puddle on the floor under my cabinets. is something blocked up...
if it has ice/water in the unit,check the hoses going from the supply line at the inlet valve on the refrigerator rear section,if theres a hole in the tube,when the ice maker calls for water to fill the ice trays it will leak out this pin hole during the time the water supply valve is open and then shut off when the valve closes due to no pressure on the line then,thats probably the reason the puddles not always there
May 13, 2011 | Maytag MZD2766GES Side by Side...
Freezer side of a side by side water in the bottom
the drain is clogged.take a hair dryer and un thaw the drain
Dec 18, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water on the floor left side of refrigerator
well theres a couple of things it will do at that frequency.defrost cycles and may be making ice.defrost water goes down a drain.ice maker fills thru tubes.also the defrost drain could be blocked you would see ice on frezeer floor.you have to us your fingers and trace out those places to find leak
Dec 31, 2008 | Frigidaire FRS23F4C Side by Side...
Side by side gallery ...water leak
  • it sounds like the water valve is not closing fast enough.
  •  this will cause the ice-maker to overflow a little.
  •  your ice-maker may have an adjustment on it to control how long it keeps the water valve on.
  • it should be a screw with a + and - sing on it. it may be under the ice-maker plastic cover.
  • if it keeps doing it then you may need a new water valve.
Jun 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
171 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
