Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
It appears that the door lock will not tell the washer its locked
  • 7 more comments
  • Pat68 Nov 21, 2007
    f 2 possible code
  • Anonymous Apr 25, 2008
    My door lock will not lock so my washer will not start
    how do you fix it?
  • Anonymous May 04, 2008
    In the middle of the spin cyle the machine shut down and the door popped open. Now the door will not close and remain shut.
  • Anonymous Jun 11, 2008
    my washer also starting having the "DL F" error code. A local repairman came about a year ago (have had my washer 3 years) and he also gave me a diagnostic repair code which I have had to use since then. This works without fail: turn on machine, turn to drain spin, hit no spin button, hit options button four times, let run fully. The turn to original cycle and wash. This has worked miracles!
  • captainron49 Jul 10, 2008
    It seems the door won't lock. We get the dl f code. Tried the suggestion from someone about setting to drain/spin, hitting the no spin button, hitting the options button 4 times, still get the dl f code. Do I need to replace a part or is there another solution?
  • Anonymous Mar 15, 2014
    where is door switch on whirlpool duet washer
  • Anonymous Mar 16, 2014
    whirlpool duet washer door boot screw broken
  • Anonymous Mar 18, 2014
    how to replace door liner
  • 67 Answers
Is there an error code?
Posted on Mar 27, 2007
I fixed my door lock problem by first releasing the door via the door release as described before. Then I sprayed just a little "jig-a-loo" lubricant spray into the door latch. I then opened and closed the door a few times and we are back in business! Hooray!
Posted on Jan 17, 2011
For the "DL F" issue, try this diaognostic code: Turn dail to drain spin cyle. Hit the no spin button. Then hit option button 4 times. Let cycle run completly. Once completed, turn to original wash cycle, and your machine will start (A repairman gave me this advice, and it works without fail).
Posted on Jun 11, 2008
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
The washer is telling me the door will not unlock but it dose
Sounds like the door lock has failed and needs to be replaced. I have attached a link so you can buy the part. DC64 00519B DOOR LOCK
Sep 08, 2015 | Samsung WF448AAP Front Load Washer
How can you tell when the door lock is bad on a 2011 frigidiare affinity front loader washer
Mike,
I understand that you are wanting to know how to tell if the door lock is going bad on your Frigidaire Affinity washer. One way to tell is if the washer is telling you that the door is not shut or locked when it is. Try to reset the appliance for 3 minutes, by either unplugging it or resetting the circuit breaker. If you are still having trouble with the door lock, I would suggest to have a local authorized technician to come look at the lock and fix it if necessary.
-Best Regards-
Jan 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Can't open door
the two possibles are faulty door lock or water still in the machine. the error code should tell you which. go to AEG and their troubleshooting page will give you the codes.
Jan 30, 2013 | AEG Lavamat 72640 Front Load Washer
Kenmore 11045981400 front load washer spontaneously fills if door is closed overnight. Then door won't unlock until machine is rebooted at power outlet
These things are getting more complex and electronic all the time and this does not help with the longevity of these units. It it telling you that there is a defective or intermittent door switch detected and when you reboot the unit it starts with all things at the zero point.
I had a high end Whirlpool washer that had so many things wrong with it by description of the service man that they replaced it after 4 years of use. No more 30 year old washers with all these circuit boards in there- isn't technology wonderful?
Oct 01, 2012 | Kenmore Elite 45986 Front Load Washer
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The load appears to have finished, but the CONTROL LOCKED light is on. The door is not locked and the washer is still full of water. Pushing cancel does not reset it.
Hello
This whirlpool duet front load washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Nov 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
I hope this helps you.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
Washer won't turn on, code FdL appears in timer window, GHW9250M
Hi. this is a Door lock mechanism error. here is a description of the code and troubleshooting tips below.
Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
You may need to replace the door lock mechanism if the wire harness checks out OK. Now, if the wires are connected well and the door lock mechanism if working, this could be a more serious issue concerning the Control board.
You can test the door lock mech by using a volt neelde or multimeter as well. use the connector clips for testing the proer voltage.
Please rate and god bless:)
May 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
728 people viewed this question
Dan Webster
Dan Webster
Sal De
