Question about AOpen XC Cube EZ915 (95EZ1592Z1) Barebone
Hi, i have finished putting up together my XC Cube EX915 Barebones, i have connected everything correctly and when i turn it on there are no beeps from the system...everything seems to run well from then, apart the fact that the screen wont show any activity, i have tried installing a Geforce 8600 GTS OC bypassing the onboard VGA but nothing seems to work, will this be a problem with the motherboard or is it something els? Geoff
  • Anonymous Dec 17, 2008
    iv tried a Geforce 8600 GTS OC if thats what you mean but no result....
  • zink4 Dec 17, 2008
  • 599 Answers
Its sounds like video issue...have known good to try as substitute to test?
Posted on Dec 17, 2008
Network driver
This barebones system is from AOpen Netherlands. They have a website for the driver downloads. Here it is:http://www.aopen.nl/products_download.aspx?sDropDownProd=4
If you like my answer, please accept it. Thank you.
Dec 24, 2010 | AOpen XC Cube EZ915 (95EZ1592Z1) Barebone
Computer beeps but doesn't start.
The beeps are an error code. Most times they are signifying a RAM or video card problem. With your explanation I would check the video card first. The card might have overheated or just plain crapped out on you. Try replacing and rebooting. Hopefully this will have fixed your problem. Sorry. Hope this points you in the right direction & Good luck.
Jun 03, 2009 | Intel AOpen XC Cube EZ65 P4 Media PC...
Computer will not boot with second hard drive
it look like harddisk problem is keep going. plug out the disk and try. if it continues and says there is not problem you can say mmotherboard is working well and you have really disk problem
May 29, 2009 | AOpen XC Cube EZ65 Barebone
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Start Up
O.K. Try this:
Turn the power off at the wall, Pull the GF card and flash the BIOS (refer to manual to locate JP1 move the jumper so that it covers the central pin and the previously exposed pin hold for three seconds and return to origional position). If you have altered any VGA jumpers put them back in their origional positions. Reboot using the unboard graphics card.
If it reboots with a nice clear beep from the onboard speaker and gives U a dsiplay we are on a winner if not we have a more involved problem.
Please please note: NEVER HAVE POWER CONECTED TO YOU SYSTEM WHILST YOU ARE ALTERING ANYTHING PHYSICAL INSIDE THE TOWER JUST DONT AND TAKE STATIC PRECAUTIONS.
O.K.: Lets just say you rebooted with display, reboot again but this time breaking into the BIOS (usualy either DEL, F2 or F10 being struck repeditaviley on boot untill the BIOS comes up). Search thru the the BIOS options untill U find one that alows u to disable the onboard VGA and often u will find one that alows u to enable the Advanced Graphics Interface depending on the manufacurer this may be a default setting that if u disable one it automaticaly enables the other or it could be called something different but u know what I mean.
O.K.: Time to check the manual if there are any onboard jumpers or such to disable the onboard VGA switch them (fairly rare for a number of years but possible). Reinstal the GF gently but firmly have stumped myself many a time and seen others do it whare a card or component feels sound but is not properly seated.
Moment of truth reboot using the GF. I this works.
If on boot u either get a string of continuous beeps or no beeps at all u have a more serious problem and a more lengthy solution. Primarily unplug everything from the MB, reinstall the CPU and the minamum amount of RAM, flash the BIOS and reboot. No beep, no display no boot back to the manufaturer/ supplier for a replacemant under warranty.
O.K. u got a beep u got a display - now it is time to start installing each component individualy starting with the minimum amount of RAM and ending with the rest of the RAM untill u can identify which component is stopping your system from starting. Identify the component get back to us and it could be a realy easy fix. You never know I once had a machine that I "fixed" worked perfectly on my bench but failled when the client got it home - finaly got the shits, striped it completely and found a loose screw under the MB that mooved every time he transported it after a fair bit of swearing I just had to laugh.
Good luck
Dec 17, 2008 | AOpen XC Cube EZ915 (95EZ1592Z1) Barebone
Start Uo
go into bios and disable the onboard video this should fix u problem
rate and vote
Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
Jul 11, 2008 | AOpen XC Cube EZ65 Barebone
Constant beeping while attempting to boot up
There is probably an issue with the RAM. Take the RAM out and put it back in see if that fixes it. If not then take it out and if you have 2 sticks of RAM put only one in at a time to see if the computer will boot on either stick. If that still does not work then most likely either all of your RAM is bad or there is a problem with the motherboard.
Jul 09, 2008 | AOpen XC Cube EZ65 Barebone
Blinking front led
Does this affect the operation of your xc Cube in any other way? If not it doesn't really matter. I had a similar issue with my pc, but it doesn't affect the operation and it doesn't really bother me
Oct 08, 2007 | AOpen XC Cube EA65-II Barebone
AOpen XC Cube EZ915 (95EZ1592Z1) Barebone Logo
107 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
