Question about Canon CLC 1000 Color Copier
I need to get the drum for clc1000 Tambour code 1355A002(AA) F43-4801-700 and the Developing
    President:
  • Canon Master
  • 990 Answers
Dear sir; please contact with me at 973-533-6778 I can get it for you. HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
CALL SERVICE 7402
Error code 7402
Developing unit C noninstalling error
No density detection signal is output from toner sensor C in developing unit C.
Reinsert the connector. Also check for continuity within the connector cable. If none,
replace the cable.
Developing unit C and Drum relay PWB
(YC10)
Drum relay PWB (YC1) and engine PWB
(YC34)
Long story short, the printer MUST go in for a service as you will void ANY warranty if you try this yourself, it is an electronic failure.
Feb 09, 2013 | Kyocera FS Office Equipment & Supplies
Error code l 4 01
L4-01 is a main motor lock error. More than likely something is locked up, rather than a problem with the motoer itself. Make sure the drum and Developing unit are turning freely. The Fusing unit binding can also cause this error. Turn the machine off, remove the developing unit and the drum. Put the developing unit back into the machine, close the doors and turn it on. If you can hear the motor run and there is no error code, then the drum is locked up, probably due to a flipped cleaning blade. The next area to check is the developing unit itself. Sometimes if the bushings go bad at the ends of the developer roller, it will cause a motor lock. There is a white coupling on the rear side of the developer unit. Turn it counter clockwise about a half turn, being careful to hold the unit level. There should be little resistance. If all seems O.K., then the Fusing unit is probably the cause. Also pull out the paper cassette and make sure nothing is preventing the pick up rollers from turning.
Aug 02, 2012 | Sharp Office Equipment & Supplies
Plesae describe the error code E00020
E020 There is a fault associated with the drum/developer.
For the first 2 digits of detail code xx12 through xxD0,
xx=01: Y
xx=02: M
xx=03: C
xx=04: Bk
xx20
xx24
xx25
xx30
xx34
xx35
xx40
xx50
The fault can occur as when a new drum
unit has been fitted. It is detected in about
90 to 120 sec after idle rotation of the developing
assembly.
unit has been fitted. It is detected during
ATR control or in about 150 sec after idle
rotation of the developing assembly.
assembly.
unit has been fitted. It is detached during
assembly.
The fault occurs when an image is being
formed. It is detected when toner supply
operation is started.
There is a fault/open circuit in
the ATR sensor. The drum unit
is not fitted normally, or is
faulty.
the SALT sensor.
the SALT sensor.
The ITB has deteriorated.
the ATR sensor. The setting of
the ATR sensor computation
value is wrong. The drum unit is
not fitted properly, or is faulty.
The sample image fails to be
drawn in ATR control. There is
a fault/open circuit in the SALT
sensor. The drum unit is faulty.
the SALT sensor.
The ATR sensor communication
value is faulty. There is a fault/
open circuit in the ATR sensor.
The drum unit has been fitted
improperly. (The machine cannot
detect the drum unit). The
The developer concentration
computation value is faulty (set
when a new drum unit is fitted).
xx60
xx70
xx80
xx81
xxA0
xxB0
xxC0
xxD0
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
new drum unit is fitted; the
value is extremely small).
The actual value is considerably
high in relation to the ITB surface
reflectance when a new
drum unit is fitted. The SALT
sensor is faulty.
drum is fitted.
The measured value of the developer
concentration is considerably
low. The ATR sensor is
faulty. The SALT sensor is
faulty. The ITB is soiled.
The drum unit is approaching
the end of its life and is causing
the T/D ratio to drop. The ATR
sensor has an open circuit.
The supply of toner for the toner
container to the developing assembly
is faulty. The developing
assembly is supplied with toner
excessively. The ATR sensor has
an open circuit.
has failed. The toner
cartridge motor fails to rotate.
The toner container is empty.
The toner supply mouth of the
drum unit is damaged. The ATR
code xxEE,
xx=00: fault in access to drum
unit
xx=01: fault in access to toner
container
The fault occurs while ATR control is being
executed.
executed.
formed.
formed and, in addition, when the T/D ratio
drops while 20 prints are being made
continuously. It is detected when toner
supply operation is started.
Aug 04, 2010 | Canon imageRUNNER C3200 Copier
Hi i am getting E061 0127 on canon clc1000, what is this error means? thanks
Basicly the code means that one of the 4 drums is not charging correctly. You may have to change the post charge wires and or one of the drums
Apr 02, 2010 | Canon CLC 1000 Color Copier
E000020-02b0
Refers to Magenta Drum/Developing assembly. Toner concentration within developing is low. Also can mean that the Drum Unit has exceeded its life. The code meaning will change to some degree depending on the specific model. On the Older CLC models that have Separate Developing Units the developer unit may need to be re-started. To check drum life. enter Service Mode by pressing on the Keyboard *28*. At next Screen touch "Copier", next Screen select Display. At the Display Screen select "Misc"
The drum life meters will be displayed. If the drum life exceeds 100% that could be the problem.
Mar 12, 2010 | Canon Office Equipment & Supplies
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Error Code E061-0110
This is an old fault.I think its a dirty drum sensor.This needs to be cleaned.Your then need to get into service and clear error code
Nov 16, 2009 | Office Equipment & Supplies
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Developing mirror needs to be cleaned. Copies have streaking and fades in and out. The technician said it was due to toner on the developing mirror. How would I clean this mirror and save the $100+ for...
Hello sir; I never heard about developing mirror, only have scanning mirror, the problem you descript, I believe is developer drum and drum blade need to replace if your machine come with cartridge then you just replace whoek cartridge.
Aug 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
Canon CLC 1000 Color Copier Logo
old marine
old marine
