Question about Directed 1100d Car Audio Amplifier
I have a 1100d directed amp and it cuts in and out as i play it sometimes for several mins... also it takes several mins to come on whan i turn on my cd player... I had a orion 600d amp right b4 this amp and had no problems so i know it has to be the amp.any help would be grateful....
  • 27 Answers
Check your connections. If everything is tight and you battery voltage stays over 12 at the amp then the amp is probably bad. Send it in for repair.
Posted on Dec 18, 2008
The green light and protection light on my 1100d constantly blink and the interior lights in my car blink in sequence with the lights on the amp and I get no sound out of the amp and sub setup. What could...
Sounds like you have an issue with the amp, the install, or possible blown subs.. check, test and if all else fails get the amp serviced or get a new amp.
A good car audio shop can also help you check it over.
Feb 06, 2011 | Directed 1100d Car Audio Amplifier
How do i connect a directed 1100d amp to a jl audio 10w3v2-dual voice coil
Hello disciple_sco,
The 3v2-D4 Jl's have 4ohm voice coils. The 3v2-D2's have 2ohm voice coils. If you have the D4, you should run the voice coils in parallel, both positives and both negatives to the respective amp terminal. This will result in a 2ohm load to the amp. If you have the D2, I'd series the voice coils, jumper one positive to the other negative and connect the other positive and negative to the amp terminals. This will result in a 4ohm load to the amp.
Hope this helps.
Jul 02, 2009 | Directed 1100d Car Audio Amplifier
I think the problem it's graphic card
Check your antivirus software. This seems to be the problem of something running in the background when you are playing the game. If it would have been the Graphics card, the game would not have worked, or would have given errors.
Try to disable your antivirus or any other program that may be running in the background. Then check once again.
May 14, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Directed 1100d is it 1 ohm stable?
I don't know how you are coming up with a total load of 1 ohm , but if you do manage to hook that amp to a 1 ohm load you will almost certainly blow that amp. Good luck and please don't forget to rate this answer.Thanks.
Apr 12, 2009 | Directed 1100d Car Audio Amplifier
Directed 1100 d turns on but no sound
hi there
few steps to try
1) try grounding amp to a new location
(make sure the amp is grounded by itself)
2) check the power wire from the battery to the amp
3) if the 2 steps don't solve the problem try turning your amp settings down and disconnect the power wire from the amp after a few seconds reconnect the power wire and amp should reset itself.........
if this doesn't work let me know there are other tricks that can be done but these are the most common firsts to be tested (also make sure the ground wire is larger than the power wire)
hope this helps
Mar 04, 2009 | Directed 1100d Car Audio Amplifier
My 1100d directed amp cuts n and out as i play it, and sometimes
most reputable car audio shops can give you (or have thier own) repair techs. is the new amplifier rated down to the same impedence you have your subs wired to?
Any protection lights coming on the face of the amplifier?
It has a lights that come on for Thermal, DC offset, over/under voltage, reverse polarity and short circuit protection.
May be a faulty turn on module.
Get it repaired before more happens internally for a costlier repair.
Dec 17, 2008 | Directed 1100d Car Audio Amplifier
Sounds problem
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Mar 13, 2008 | Directed 1100d Car Audio Amplifier
Directed 1100d 2-channel amp
You will bridge the amp, and if the subs are all 8 ohm subs, you can probably wire them all in parallel, if they are all 4 ohm subs, you would wire then in series.
Oct 17, 2007 | Directed 1100d Car Audio Amplifier
Directed 1100d Car Audio Amplifier Logo
66 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
