Question about Philips Magnavox 55P9271 55" Rear Projection Television
My 55in magnavox is to blurry and the colors are to bright
The colors on my tv are way to bright. I can not get them to straighten out, also the words are blurry. When you have the guide menu up for direct you can't read it. I took the back off and tried adjusting the projectors, but I do not know where to adjust them to. Anyone think they can help?
    Problem Solver:
  • 8 Answers
Sounds like a convergence repair is needed that is what happend to me! and the cost is pretty high $300-$400 unless you can do it your self
Posted on Jan 28, 2009
Fuzzy with double picture
TV is blurry as if expanded, do not know how this happened. Words are blurred, picture is not crisp anymore. Help please.
Aug 12, 2010 | Philips Magnavox 27MS343S 27" TV
TV picture is very blurry and fuzzy
Replace the CRT coolant. Very common problem with Phiullips/ Magnavoxs. You can get the CRT coolant kit from www.tvrepairworld.com which has the coolant for all three colors and the cd with instructions.
Jul 27, 2010 | Philips Magnavox 51MP392H Rear Projection...
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color setting
MOST likely, use remote [maybe set] for <menu[setup]> <video>. This is normally where <brightness><contrast><color> and so forth live.
Jul 27, 2008 | Philips Magnavox 20MT133S 20" TV
Brightness on VS-50605
The darkness shouldnt be that exspensive some trouble shooting and a few dollars should straighten that out. The screen however will cost a couple of hundred dollars, although that would still be cheap for a big screen, and that model does play exceptionall well when operating properly.
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Philips-Magnavox 9P5534C103 55IN. PEAR PROJECTION
TV does not display picture on whole screen....it has three smaller colored rings with the picture inside of it
Jun 01, 2008 | Televison & Video
Projection tv philips magnavox 9p5031c101
power supply problem .the cherps are the power supply ossiclating and trying to produce . soon you won't even hear that
Aug 06, 2007 | Philips Magnavox 9P6034C 60" Rear...
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Philips Magnavox 55P9271 55" Rear Projection Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
