Question about Linksys Wireless-G WRT54G Router
Ip of computer 169
The computer is getting a 169. ip ,, how should i decrease the speed of my netwoek card
  • gunjan malhotra
    gunjan malhotra Mar 27, 2007
    man you are cool
    === can i also try this form device manager.
    Scholar:
  • 113 Answers
- Go to the control panel - Go to network center - Open the local area connection properties - click on the configure button - click on the advanced tab - look for any property that says 'link speed and duplex' or 'speed and duplex' - change the value of this property to '10 mbps half duplex'
Posted on Mar 27, 2007
  • Sandeep Bakshi
    Sandeep Bakshi Mar 27, 2007
    This would be done only from the local area connection properties under network center.
    So, where have we reached till now. Did the steps work?
Wireless router is connecting to a 169 ip address instead of a 192 ip address. I know it's an issue regarding the DHCP server but it's not making any since, since I've done ipconfig /release, renew and it...
When your computer is trying to request IP address from a DHCP server but it does not see the DHCP server it will give up and make up an IP address for itself. This IP will often look something like 169.x.x.x. This is a fake local address that Windows assigned to your PC when it couldn't reach a DHCP server.
Make sure that your computer is connected to a network with working DHCP server.
Jun 09, 2010 | Dell Inspiron 530s Desktop Computer...
Hi, i am using dell insprion 1525 laptop. i am faceing problem in netwoek drivers . i am not able to install network drivers and at lan card palce i am getting red light please help me .. praveen kumar
Boot the computer in Safe Mode with Networking and see if it connects that way. If not, try this fix.
TCP/IP stack repair options for use with Windows XP with SP2/SP3.
Start, Run, CMD to open a command prompt:
In the command prompt window that opens, type type the following commands:
Note: Type only the text in bold for the following commands.
Reset TCP/IP stack to installation defaults, type: netsh int ip reset reset.log
Reset WINSOCK entries to installation defaults, type: netsh winsock reset catalog
Reboot the machine.
Download Network driver :- R161378.EXE on support.dell.com
Jan 16, 2010 | Dell Computers & Internet
Hello, my computer has an 169 ip address, i've tried to renew the ip it wont renew it, but other computer works fine on the same router, any suggestions how can i get rid of that 169 ip address? thanks
First make sure your network connection is plugged in and working (i.e. look where the cable goes into your computer and has a green light on near it). 169's a re the windows default when no connection is available.
Then, if the cable (or wireless connection?) is OK, click on start > control panel> Netwok and internet connections>
Click on your Lan (ow WLAN?) connection and hit properties.
Navigate down to the 4th (or 5th depending) in the top box to TCP/IP and highlight it, hit properties, and select "automatically configure" for both the IP adress and DNS Servers, hit Apply, then OK, wait a few seconds and you should be good (assuming it's not actually your router handing out the "169" adress.
If all is not well, try a different network cable or port on your router, or get back with more detail.
Dec 28, 2009 | Microsoft Windows XP Professional With...
My dell inspiron 1300 wont connect to my tplink w8920g wireless router.. need some help =)
Do you have the driver installed correctly.From a command prompt if you type ipconfig do you get a 169 .ip address if so windows is assigning a ip address to the adapter.Remove the card from the computer,Uninstall the drivers and softtware, reboot.Once windows have come up make sure the drivers and the software are uninstalled.Shut windows down again reinstall the card once windows is up reinstall the drivers and hardware.Make sure to let windows manage the adapter and not the software that came with the adapter.
good luck
Nov 02, 2009 | Dell Dimension 4600 PC Desktop
PC can't pull an IP address from a working connection
if you have xp download wifiradar or wifimanager search these on youtube
Mar 28, 2009 | Microsoft Windows Server 2003 Enterprise...
ST516v6 Modem has all lights except the Internet.
Check your IP address, go to start... run... cmd... and type in ipconfig... if your ip address is 169.xxx.xxx.xxx then you need to troubleshoot on your computer.. get a local tech to help you out.. if not then the ip should be 192.168.1.xxx thats the residential gateway....
was i help ful?
Nov 18, 2008 | Computers & Internet
Help
hi there,
if your computer has an ip address starting from 169.xxx.xxx.xxx then that is an invalid ip address... refer to computer vendor for another nic card.
Your ip address can be found by accessing the command prompt..
eg in XP
Start> Run> type in the run box "cmd" in the black dos window type in "ipconfig" press enter.
this will give out ip address, subnet mask and the defualt gateway.
Sep 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Limited or no network connection
looks like the dhcp is your problem.
the error is telling you that its an internal network providing limited access.
go to run cmd then in the dos prompt type in ipconfig /all
see your network card's ip address. if its 169.x.x.x then thats the problem..u are not getting the ip address from your computer.
go to your network connections right click the network card then go properties in the tcp/ip area assign yourself a manual ip address of 192.168.1.xx
the xx is a number that u like 2 digits only but it can't be 1
your default gateway is your router so give it 192.168.1.1
this should solve ur problem
good luck
smeags
Jan 19, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
77 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
