Computer:Acer 3053WXM1 notebook-serial number:64603188225 When I try to write to CD the CD Writing Wizard is telling me-NO DISK IN DRIVE E even though there is a CD in the drive.Also it will not read installation CD'S EXAMPLE printer set up.Also it will not play DVD's
  • Anonymous Dec 25, 2008
    I am still trying to find the appropriate Acer website to update
    CD driver.I tried to contact Acer by phone,but found myself 40th
    in line.Do you know the website address?.
  • 145 Answers
Please update drivers for your CD/DVD writer from Acer website. that will solve the problem. Additionally buy a Good qyality CD/DVd lens cleaner and use it to clean the lens of the CD/DVD writer
Posted on Dec 19, 2008
My DVD/CD ROM is showing no Disk in the drive (E:), while there is.
is it a blank cd? if so try going to the start menu my computer right click on drive (E:) properties and make sure writing on this device is enabled if its not a blank cd but a copied one it may be the disk thats the problem not your computer. if its a shop brought music cd copyright protected it may not read it because of copyright laws!!! if its like this with all cds then you laser may be faulty
Jan 11, 2011 | Acer Aspire 5315 Notebook
My Cd-Rom doesnt work for my Acer Notebook 2930
Got to the Acer Web site and look under drivers and downloads. Select your model # and download the corresponding drive. Your prblem should be fix
May 15, 2009 | Acer Aspire 5100 Notebook
Writing/Erasing CDs in Windows XP without any Software
1) Insert CD/DVD disc you would like to erase into the CD/DVD drive
2) Start My Computer
3) Double-click on the CD-Rom drive to open disc.
4) Click Erase this CD-RW on the left panel
4) Click next at the (CD Writing Wizard) screen
5) The CD Writing Wizard will appear
6) Click Finish
on Aug 31, 2010 | Computers & Internet
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Sony Optical Drive Optiarc CD-RW CRX880A Problem!
First, I would try burning at a very slow speed to see if this helps. If it doesn't help and you think the burner is just worn out you can buy a USB burner for about $50
Feb 27, 2017 | Sony Computers & Internet
Acer 6930 recovery problem
About the only thing to try is to find another person with the same PC.
Remove the disk-drive from your computer.
Remove the disk-drive from the other computer,
and install your disk-drive.
Run the Restore Disks on that computer,
which will restore to _YOUR_ disk-drive.
When complete, remove the disk-drive, and reinstall it in your computer.
It should boot, and run properly.
Could it be your CD-ROM drive that is intermittently failing?
Nov 18, 2009 | Acer Aspire 6930-6455 Notebook PC
Disk drive not reading disk
Try using another computer or laptop to rip the CD if you encounter the same problem then the cd is unreadable or dirty try cleaning the cd
Nov 18, 2009 | Acer Aspire 5520-5908 Notebook
Unmountable boot volume acer 3000 aspire
Unmountable boot volume is Hard Disk Partition lost.
There are two partition on hard disk, one is NTFS & FAT32, if this two partition are damage or lost, then you have lost your data also.
Reformat on it are the best way result and put new windows system.
You can recover your pictures after reformat by using a program RECOVERMYFILES, this program even when your windows system got reformatted can recover all of it.
Please don't forget to rate me.
Thank you.
Aug 17, 2009 | Acer Aspire 3000 Notebook
Hello nascarmom60,
If there is a disk in the cd tray, remove it and try rebooting. If the problem comes back again then the operating system may be corrupt and will need to be restored if you have a restore disk available.
Another thing you might want to try is to reboot and press the F2 key as soon as the ACER logo appears on the screen to bring up the setup screen.
•The top row of the setup screen shows the menu choices (Information, Main, Security, Boot, Exit). The bottom 2 rows show which keys to use to move around in the setup screen.
•Use the right arrow key to move to the 'BOOT' menu option. The boot menu shows the order of devices accessed for booting the system. The order should be 1:IDE 1, 2:IDE 0, 3:USB FDD followed by other numbers.
•IDE 1 is the cd drive - IDE 0 is the hard drive. It's possible that the ACER AS5315 was trying to boot up on the cd drive (IDE 1) instead of the hard drive (IDE 0).
•Use the right arrow key to 'EXIT' the setup screen then use the down arrow to select 'Exit Discarding changes'. Press enter. I hope this is useful and a full system restore will not be required.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
Jul 28, 2009 | Acer Aspire One A150-1049 Notebook
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
