Question about Amana AOCS3040 Electric Single Oven
Amana Convection Oven AOCS3040 fan stops working
Sometimes the oven fan will stop working once the oven has been turned on "convection". Other times the fan will not turn on at all. My husband replaced the fan thinking it was the problem, but it apparently was not.I have been searching for instruction for the control panel wires to see if there is a possible short in the panel. I cannot find any information on which wires in the panels control the features of the oven. Any suggestions?
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Posted on Feb 23, 2008
SOURCE: On a Amana EvenAir convection Plus oven the
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Posted on Oct 14, 2009
  • 99 Answers
SOURCE: I have an Amana AOCS3040 convection oven. The
Sounds like the element shorted out. I recommend having someone look at it or go out and buy a new oven. Either way you will have to spend some money to get someone to get your oven repaired/replaced.
Posted on Feb 12, 2011
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
F1 error on SS Amana Convection wall oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Jun 03, 2008 | Amana AOCS3040 Electric Single Oven
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Amana AOCS3040 Convection Oven
If I were you I would contact Amana and speak to their service dept. and tell them your problem as maybe theres a service bulliten out or a common repair and if that they would recommend someone who can fix this model.. I tryed to look up this model and I couldnt find it. If that dosent help Go to http://repairclinic.com and ask the repair guru there for assistance.. Good luck
Apr 16, 2006 | Amana AOCS3040 Electric Single Oven
Amana AOCS3040 Electric Single Oven Logo
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
