Question about RCA T13208 13 in. TV/VCR Combo
TV On/Off button blinks but never turns on.
Remote was bad so I purchased a new remote and in programming the new one I managed to somehow program the TV so it now won't turn on. The problem is, to program the remote you need to have the TV on but thats not happening. The on/off light flashes but the TV never turns on. What next? I've unplugged from the wall thinking that would reset but that didn't work. Thanks for any help. Lee T.
    President:
  • 3,130 Answers
Ok you did not cause the problem as you could always turn on the TV set from the front panel button,, If the TV set will not turn on even with the front panel button, there is a major fault with the TV set. This is not a reset that can be done by the user as there is a circuit fault and will require you to take the TV set into a shop to be diagnoised or replaced. Good Luck
Posted on Mar 27, 2007
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
I need the steps to program the urc4021 remote, as well as the code for the sanyo tv
To program the One-For-All URC4021, first turn on the TV manually (or with the original remote). Press the TV button on the URC4021 once. Then press and hold the Set button until the LED blinks twice. Now you can enter a code directly and test it. For Sanyo TVs, the only programmed code is 0154 . If the LED blinks twice, press Power to attempt to turn off the TV. If that works, you can turn the TV on again and test if the other buttons on the remote work with your TV. If the LED doesn't blink twice, repeat the steps from pressing and holding Set. (If you wait too long before entering the code, the remote will leave the programming mode.)
The URC4021 has a code search mode. Press and hold Set until the LED blinks twice, then press 9 9 1 . If the LED blinks twice again, alternate between pressing the Power and TV buttons until the TV turns off. Then press Set to lock in that code and test the remote again.
I hope this helps.
(Note: if your TV is newer than the remote or released within 6 months of the remote being programmed, this code may not work. The URC4021 documentation gives March, 2004 as the copyright date. That suggests that the codes may not work with devices built in 2004 or later.)
Sep 29, 2015 | Sanyo Televison & Video
How do i program a jumbo universal remote to my seiki tv
you cant,
Follow these steps to program a device into your remote control. There are two ways to program your remote. If you already know the code for your device, you can program it into your remote manually. If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote.
TV Codes
TV Code List
ACME ADA ADC ADMIRAL ADVENTURA AIKO AIWA AKAI ALLERON AMARK AMTRON AMSTRAD ANANATIONAL AOC APEX ARCHER AUDIOVOX BANG&OLUFSEN BELCOR BELL&HOWELL BRADFORD BROKSONIC BROKWOOD CANDLE CENTURION CAPEHAPT CENLEBRITY CENTURION CETRONIC CHANGHONG CITIZEN CLQIRTONE CLASSIC COLORTYME CONCERTO CONCIEREG CONTEC/CONY CRAIG CROWN CXC DAEWOO DAYTRON DIMENSIA DUMONT DYNASTY ELEKTRA ELECTROBAND ELECTROHOME EMERSON ENVISION FISHER FUJITSU FUNAI FUTURETEC GE GIBRALTER GRUNDY HALLMARK HARVARD HITACHI HAIER IMA INFINITY INTEQ JANEIL JCB JC PENNY JENSEN JVC KAWASHO KAYPANI KEC KENWOOD KLOSS NOVABEAM LG (GOLDSTAR) LODGENET LOEWE LOGIK LUXMAN LXI MEGATRON MAGNAVOX MAJESTIC KONKA MARANTZ MEGATRON MB MEMOREX MGA MIDLAND MINUTZ MITSUBISHI MONTGOMERY WARD MOTOROLA MTC MULTITECH MULTIVISION NAD NEC NIKEI NIKKO NTC ONKING ONWA OPTIMUS OPTONICA ORION PANASONIC PHILCO PHILIPS PILOT PIONEER PORTLAND PRICE CLUB PRECISION PRISM PROSCAN PROTON PULSAR PULSER QUASAR RADIO SHACK REALISTIC RCA RHAPSODY RUNCO SAMPO SAMSUNG SAMSUX SANSUI SANYO SCOTCH SCOTT SEARS SPELTRAVISIO SHARP SHOGUN SIGNATURE SIMPSON SONIC SONY SOUNDESIGN SQUAREVIEW SSS STARLITE SUPRE-MACY SUPREME SYLVANIA SYMPHONIC TANDY TATUNG TECHNICS TECHWOOD TEKNIKA TELECAPTION " TELERENT TERA TMK TOSHIBA UNIVERSAL VICTOR VIDTECH VIKING WARDS WHITE WESTINGHOUSE YAMAHA ZENITH
Jun 29, 2015 | Universal Televison & Video
What is the code for a sanyo tv and how do I program it
If your TV is older than the URC-4220, the code should be 0154. (The universal remote generally can only control devices that were released about 6 months or more before the remote was programmed.)
To program the remote, turn on the TV manually. Then press the TV button on the remote once. Press and hold Set until the LED blinks twice. Release the Set button at that point. Enter 0154, check if the LED blinks twice again. If the LED blinked properly, point the remote at the TV and press Power. If the TV turns off, this is the correct code. If you take too long between steps, the remote may leave the setting mode. If the LED didn't blink, start over from pressing the TV button on the remote.
The manual for the One-for-All URC-4220 remote is available here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/11828/~/programming-and-operating-the-oneforall-urc4220-universal-remote-control . Scroll past the directions for using and programming the remote to the link to the Owner's Manual. The list of codes starts at page 36.
I hope this helps.
CIndy Wells
Feb 10, 2015 | One For All URC4220 Remote Control
Need Time Warner remote codes for a TLC TV
There are no Time warner codes for TCL tv's. You will have to perform a "code search"
1 Turn on the device that you wish to program. If you are programming a DVD or VCR player, then insert a media disc such as a DVD or VHS tape.
2 Press the device key on the remote once. This remote is capable of programming five devices, and each has its own respective button at the top of the remote. For example, if you wish to program a TV, press the "TV" device key at the top of the remote. The device key will blink once.
3 Press and hold the "Setup" button on the remote. The selected device key will blink twice, indicating it is ready to be programmed.
4 Enter "991" on the remote. The device key will blink twice again.
5 Aim the remote at the device you wish to program and press the "Power" button.
6 Press the "Channel +" button on the remote. Continue to press that button until the device turns off. Once that happens, press the "Setup" button to lock in the code.
7 Press the "Power" to turn the device back on and it will be ready to use
May 15, 2012 | TCL LE24FHDD20 24-Inch 1080p LED HDTV
Need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Jun 04, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 08, 2011 | Televison & Video
I lost my code sheet. how do i get a new one.
Try to do this:
Guide to Programming the Remote
Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
Using Code Search:
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
SOURCE
Sep 29, 2010 | Innovage Jumbo Remote Control
I have a rcr3273 universal remote. my tv is rca. i had the remote programmed before and somehow it became unprogrammed. i dont have the instructions anymore and i cant get it working
hold down tv button and power button together until the lcd light turns on. then press the play button every 5 seconds until your tv turns off. press reverse every 2 seconds until it turns back on. press stop to save the programming code.
Nov 09, 2009 | RCA Universal Remote Control
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
Oct 02, 2009 | One For All URC-3021 Remote Control
RCA T13208 13 in. TV/VCR Combo Logo
147 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
