Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman downdraft LP furnance interal fan wont kick on.
I have a coleman furnance, the green light flashes 3 x's, and the internal fan wont turn on. I put on a new pressure switch. If I hard wire the fan it will run, when I test the wires that run to the fan I get no power. Could you have answer for this problem.
Thanks,
Scott
    Top Expert:
  • Coleman Master
  • 9,798 Answers
Do you have a wire from thermostat?
Posted on Mar 13, 2018
  • Coleman Master
  • 2,156 Answers
Need to find where the voltage stops. High voltage coming in, through possibly a board, through a sequencer or relay. Trace the wires from the power source.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Feb 24, 2018
    Top Expert:
  • Coleman Master
  • 28,685 Answers
You could have the control board repaired, I would repair it.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 541 Answers
You have a bad control board. Replaced the board
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
SOURCE: Coleman Gas Heater for home
I have a Coleman gas heater. My heat won't come on. I can here the blower comming on when I turn on the thermonstat. However no heat will come out. I went up in the attic and the heater instructed me not to light it with a flame. There was a yellow spiral kind of pipe with what look like a little yellow open and close valve. It looked like you should turn it and let the gas come in the heater from the gas line.I wasn't sure if it really was how to turn on the heater. I need some help. should I call the gas company or another company.
Posted on Nov 06, 2008
  • 70 Answers
SOURCE: i have a coleman/evcon electric
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Posted on Jan 21, 2009
FunnyPlumber
  • 43 Answers
SOURCE: where can I purchase parts?
Try Orange County Appliance Parts in Garden Grove, CA. http://www.ocapsupply.com/
Posted on Jun 25, 2009
SOURCE: Coleman Mobile Home Furnace - Error Code Flashing Two Times
Our mobile home has a 1996 Coleman Evcon. We noticed dripping of water onto the front and back, dripping on the wires. A tech came, repaired the drip pan and cleaned the coils. Didn't help. The tech siliconed around the entire drip pan. Didn't help. The tech cleaned the entire unit where coils are. More water. What should I do next?
Posted on Aug 03, 2009
Coleman furnance model 4084a656 sometimes it wont light burner can hear purge motor running cycle thermostat than it starts
i have a question if the fan wont kick off does anyone know how to fix it if you have any answers email me them at kingskylar4@gmail.com please and thank you
Oct 23, 2012 | Heating & Cooling
Coleman mach furnace wont stay running. i turn the thermostat down until i hear it click, then i turn it back up to get the furnace to kick on.works sometimes and sometimes not. blower will always kick on...
Hi, I don't know if you are still having a problem, but it sound like the flame sensor on the unit is dirty and need to be cleaned. If it has a automatic pilot, it will have a flame sensor. Its made of porcelin with a metal rod coming out the end, laying next to the pilot flame. Just 1 screw holds it in place. Remove it and clean the tip with steel wool or a piece of sanding cloth. If you don't have this set up, I would need more info on the unit, model and serial number. You may also have a faulty thermostat, but I do believe it is a flame sensor.
Shastalaker7
Nov 21, 2011 | Coleman Mach III Air Conditioner
My blower wont shut off on my furnance
You can flip the switch in the fuse box, and that will shut it off
Mar 29, 2011 | Coleman Cable Double Pole 60a Circuit...
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Triple rocker switch to control 3 function bathroom fan/light
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
Mar 08, 2010 | Leviton 1755 Triple Rocker Switch Decora
Heating & Cooling Logo
112 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Paul
Paul
Craig Butler
Craig Butler
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
