Question about Acer Extensa 5620 Notebook PC
Plastic casing over notbook hinges broken.
I have the Acer Extensa 5620 Notebook, and the plastic part that covers the metal hinges is cracking badly. I have contacted the manufaturer, but have gotten nowhere with ordering a new casing for the whole notebook. Any suggestions for a quick fix, or ideas where to look online to buy new casing?
  • 408 Answers
I would go to Ebay and search for them.You can get most parts alot cheaper,especially hinge covers.
Posted on Jul 28, 2009
    Scholar:
  • 86 Answers
Look on ebay for hinge covers. Sometimes you will find them on there. Good luck!
The cover on my extensa 5620 - 6419 crack near both hinges
Go to www.ebay.com Type: make and model of your laptop and scroll through the pages looking for replacement parts.
Apr 21, 2012 | Acer Extensa 503T Notebook
Show me where the power button is
http://www.insidemylaptop.com/replace-broken-display-hinge-in-acer-extensa-4620z-laptop/
Scroll down to the photo under Step 1.
On the cover that is being lifted in the air, look at the button at the bottom/right.
Circle that is open at the top, with a line coming through the opening, halfway.
Power On button.
Doesn't work? Perhaps you have a bad Power On switch.
(Located under the Power On plastic button)
For additional questions post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Acer Extensa 4620 Notebook
The plastic case of the screen is cracking badly. What shall I do?
U should take it to service center.If it is under warranty it can be replaced free of cost.
Jan 09, 2011 | Acer Extensa 5620 Notebook PC
The lid is very stiff to open and is cracking the casing
The hinges need to be serviced by a computer technician, using light oil. They may need to be replaced. I have seen this happen and if not sorted out, the hinges themselves break or the main chassis frame breaks. In which case it may be better to buy a new laptop. Get it sorted as soon as possible!!!
damnor01
Nov 26, 2010 | Acer Extensa 5620 Notebook PC
My laptop is Acer Extensa 7620G...I want to change the plastic casing of LCD as it has cracked..I have unscrewed the screen but finding difficulty to take off the hinges..please help
Screws ... under plastic with little covers ...typical covers is always hidden ... don't forget if something block your plastic,and you can not open in 90 % cases is screws ... I need see this model Acer Extensa..
Aug 23, 2010 | Acer Extensa 7620-4021 Notebook
I have an Acer Extensa 5620 with a small lid closing problem
I have had this problem on several Acer models in the workshop and cured them in slightly different ways.
Method 1
The first had hinges that felt slightly rough and not smooth operating when closing the lid. This was cured by applying a very short spay of aerosol silicone grease to the hinges and wiping off the excess. It seems that dirt sometimes gets in the hinge and can prevent the hinge from closing properly. It’s a very fine amount to stop the sleep switch from activating.
Method 2
On the second the case seemed to be square and there were no seeming misalignments with the screen hinges etc. It also moved freely but did appear to be slightly worn so instead of replacing the entire screen surround and with the customers agreement I had to resort to a very small blob of two part epoxy resin on top of the protruding plastic nodule. This was filed, with a needle file, to remove a slight overhang and coloured black. Now no further problems.
Method 3
The third laptop had the screen removed and the hinges cleaned with isopropyl alcohol and then a smear of aerosol silicone grease applied to the hinges before reassembly.
Method 4
The fourth was the most expensive option as the screen surround had to be replaced. To do this gently remove the 4 black rubber inserts on the screen surround face and unscrew the 4 exposed screws. Gently lift off the screen surround and replace with the new one. Reinsert the 4 screws and replace the 4 black rubber inserts to hide the screws. Removal of the screen surround also gives access to the hinges.
Oct 26, 2009 | Acer Extensa 5620G-832G25Mn Notebook
Hi, my laptop's monitor is broken, I mean the plastic top cover is broken by the corner where the hinges are to open and close. The monitor is still in place but I fear the monitor to come apart any moment...
If it is a minor crack you can actually use Krazy Glue. Use it sparingly and let it dry completely. Be careful not to glue the hinge in place.
Another option is to search for a replacement on eBay. Just search for "Acer Extensa 5420-5687" It would be best to have an assembly manual for this task. Ask the seller of the monitor for help or check Acer's website.
I recommend using a digital camera and taking pictures as you go to make sure you can put it back together correctly. Make sure you have the correct size screw driver and be very careful not to strip the screw heads.
Last resort is to send it in for repair but that may cost more than replacing it.
If this helps please vote for this solution.
Aug 18, 2009 | Acer Extensa 5420-5687 Notebook
ACER extensa 5620 drivers
Pls. visit the link http://tinyurl.com/3vs5c2 which will help you to download the driver for the computer.
Sep 22, 2008 | Acer Extensa 5620-6119 Notebook
Hinges
You will have to buy the hinges, and take apart the laptop. Hinges are usually metal, most likly just the plastic covering the hinges are cracked.
Aug 14, 2008 | Gateway 7330GZ Notebook
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Acer Extensa 5620 Notebook PC Logo
628 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
