Question about Frigidaire FEF336BC Electric Kitchen Range
I have a kenmore elite that has a f30 error can i fix this myself
I unplugged it and removed the back of the panel ....now where do i look to solve this error
  • 15,935 Answers
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Kenmore Elite 5t shows an F30 code, water fill solenoid is making a noise like its not opening
This is a dispenser motor issue. If you pull the unit out and remove the 3 screws coming into the back of the top panel, you can remove the top panel to access the top of the dispenser. There is a motor that turns a plastic lever on the dispenser. you might be able to manually help the arm move to get past the error code, but ultimately you will need to replace the dispenser motor. Here is the part to order.
Dec 03, 2012 | Kenmore Elite HE5t Washer
Softener does not dispense and we get a code F 30
This error code F30 flashes when the central control unit (CCU) cannot drive the dispenser motor to the proper dispensing position and hence the softener dispensing problem. Disconnect power then remove the top panel and check the dispenser motor assembly for damage or broken parts. You may run a diagnostic test then take a look at the dispenser motor and observe how it behaves. Replace the dispenser motor assembly if damaged.
Click on the link below for the troubleshooting details of this problem and instructions on how to run a diagnostic test.
Troubleshooting Error Code F30 on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Elite slide in range. The stovetop works fine along with the twist knobs. But the touchpad buttons and the oven doesn't work at all. When i tried unpluging it to reset it, it flashes an...
The F30 error code means the temperature sensor probe is open. First check the wiring, then check the probe. And if necessary, switch to a meat thermometer instead of a sensor probe. F31 is the error for a shorted temperature sensor probe.
Dec 27, 2017 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore elite 49962 washer error code f30
hi sir, please check the following link. it tells about cause of the problem[Error Code F30]. http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
kindly rate me.. thanks for using fixya..
Feb 11, 2010 | Kenmore 49972 Front Load Washer
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Installed new EOC for Sears Kenmore Elite 790 46609500 oven.
Jan 02, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He5t front load waher
hey there is a temo fix till some body comes to your home if you remove the soap try and reach in to the back of the opening you can rest the spring loaded wheel that controls the soap disspenser and that will stop the clicking and allow the machine to run!!!!! after reading all the post i could find i figured it out now my washer is running fine!!!
Mar 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 | Ovens
Frigidaire FEF336BC Electric Kitchen Range Logo
264 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
