Question about Eureka Vacuums
Electrical connection to Eureka Powerhead.
Eureka powerhead for central vac. At the powerhead end of the hose is a plastic handle. Inside this handle is the end of the hose with connections for the wires that turn on the central vac and powerhead brush. The connections are made via 4 metal rings that slip over the 4 wires, each ring separated with a plastic ring. The end ring (nearest the end of the hose) will slide off of the wire with the slightest jar. How do I “fix” this ring inplace, but not permanently (glue) incase future repair is needed? Thanks.
LizDahl
  • 75 Answers
SOURCE: Electrolux Epic 6500 Powerhead Motor
Call an Aerus Electrolux dealer in your area.
Posted on Jan 29, 2008
ukvacfan
  • 328 Answers
SOURCE: Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Posted on Nov 14, 2008
RockyNR1
  • 324 Answers
SOURCE: powerhead on rainbow not working
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Posted on Nov 25, 2008
  • 78 Answers
SOURCE: Powerhead for Phantom Lightning - I need one too!
u'll definity get a new one for it, no worries just call the customer care, they will provide u with the new one, cost some 2-5$ .. thank u
Posted on Jul 17, 2009
  • 53 Answers
SOURCE: I have a hoover celebrity QS wuith the power head.
You have done very well keeping this appliance working since 1975!!!
Lucky you!
I'm not certain you would be able to get replacement parts for this model any longer,
Maybe you will just have to continue with the powerhead only.
Posted on Nov 17, 2009
Beam powerhead looses power intermittently
very small wires in back of the neck check them take off the back part of the neck
Jan 10, 2013 | Beam Industries Vacuums
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
My Dyson DC17 is picking up on the floor, but the wand is not working. I cleaned out a clog from the port in the back, but the wand still isn't working.
If there's no suction at the end of the wand, check at the end of the hose. If none here, then there's none at the powerhead, so it's not picking up either.
Check the hose. A clog at the tank port generally result in a clog in the hose as well. If none are visible, detach hose completely, hold one end up and drop a coin in. Lifting the hose should result in the coin falling through. Not doing so means a clog. You may be able to push it through with a broom handle. If that doesn't work, try holding the powerhead end of the hose to the tank port. Turn the vacuum on. This may provide enough suction to pull the clog through.
If not, and you have access to a shop vac or air pressure hose and generator, try blowing the clog out with one of these. Or you can buy an air mattress pump and try that.
Mar 09, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The vacuum only allows the brush to spin & has a high pitch sound?
This is usually caused by a clogged air flow. Start with making sure the filter is clean.
Check behind the filter, at the inport hole. This is a common place for clogs to form, then back up into the hose.
Detach the hose at both the tank and powerhead. You may be able to see a clog at either end. If not, hold one end up and drop a coin in. Lift hose so coin drops through. If the coin doesn't exit, there's a blockage. You can clear it by using a broom handle to push it back through.
Check the powerhead where the hose attaches. If a clog isn't visible, drop a coin in the opening. If it doesn't fall through, the clog can be cleared by using a wooden spoon handle, or similar blunt object, to push it through to the brush and out.
For additional troubleshooting, see the manual located below.
http://www.eureka.com/service/manuals/77418_r2.pdf
Mar 01, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
The powerhead cuts in and out on power as you vacuum with the brushes. Works ok with suction only. Have replaced both wands and still cuts out, Can it be the powerhead connections? Help? TJZ
had the same problem with mine check all the prongs on the 2 wands and on the power nozzle and on the handle itself you will probably see that one of them is discolored or burned looking you will need to replace that section, I had to replace one of my wands, and then a second time I had to replace the hose section with the handle attached.
Oct 04, 2009 | Eureka 6984A Bagged Canister Vacuum
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Feb 21, 2008 | Miele Red Star Bagged Canister Vacuum
Brush does not turn on my vaccum
When you attach the hose to the wands, there is a connection made between the hose electrical receptacle and the cord from the powerhead. On the Kenmore, it is common for the receptacle on the hose to break away from it's seat and slide back into the handle. When this happens, the receptacle is not positioned far enough forward to make the plug-in connection. Look at the end of the hose and check the receptacle and see if it is sitting flush with the plastic opening that it sits in. If it is pushed back, that's your problem. Also check the re-set breaker on the powerhead. If you got something caught in the brush roll, the breaker will have kicked out to protect the motor.
Jan 20, 2008 | Vacuums
Loose Wand Connection
its just worn, sometimes getting a new lower wand can fix this
Jan 18, 2008 | Vacuums
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
47 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
