How do i find av on my dvd recorded please - Televison & Video
  • nicki_young_ Dec 17, 2008
    Hi thanks for your help - i have found the "source" button and i get video - s-video - prog 1 - scart but i cannot for some reason get sky through to the dvd !!!!!!!!!!!!!!! I think i have put the scarts in right but who knows lol. Thanks again anyway
    Problem Solver:
  • 12 Answers
Ensure the DVD rec is conected correctly and you can see a picture on your TV from the DVDr. See if there is an "in-put" button. It might be lables Line-In, or Input or simply be a circle with an arrow pointing into it. Also try channel down, past channel one, sometimes is scrowls through the A inputs.
Posted on Dec 17, 2008
Fault A2
Are you SURE it's a fault code, and not the selected AV input? (A1, A2 or A3?
Press the Input Select button on the remote to cycle between AV inputs and Freeview channels
Jun 22, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I can't record a DVD from VCR. I tried hooking straight to front av jacks,no luck. I have dish network it's set on channel 25,video 1 on the tv. No problem recording from dish,just can't get it to record...
You need to select front AV as you video source on the DVD recorder if using the front AV phono connectors. Make sure the lead you use from the VCR is working y connecting the AV leads directly to your TV if possible.
Mar 03, 2011 | Philips Magnavox MWR10D6 DVD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
NO AUDIO ON MAGNAVOX ZV420MW8 RECORDING SECTION
Are you using AV cables (Red, Yellow, White).
One of your AV cable connections may loose or disconnected.
I hope this solution is helpful. Please remember to rate this solution.
Feb 03, 2009 | Philips Magnavox DVD/VCR Dual Player
No picture
Look under your tv settings for the pal ntc settings if you are using the av wire, if not please tell my what yoiu are using, also mak sure that youve pluged the av wire in the yello conecter av out on dvd/vhs and @ the tv AV in
Jan 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have a d-vr5sc and I would life to know how to record multiple VHS onto a single dvd. I have a number of short home movies that should fit easily onto one disc
Record them one by one using an av cord with the AV output of your VCR plugged into the AV input of your DVD recorder. After they are all recorded, finalize them.
Aug 04, 2008 | Toshiba Televison & Video
SANSUI 218 - 250gb DVD Recorder Black & White
Send it back under warranty -- needs new main board.
Rudolf
Oct 20, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
