Question about Gateway MT6729 Notebook
My gateway laptop does not want to charge the batery
Notebook 1 year of purchase.
  • 1 more comment
  • acosta_marit Dec 29, 2008
    Thank you for the help. I appreciate it.
  • Anonymous Feb 18, 2009
    my gateway laptop will not charge the battery- there should be a little purple light that indicates that it is charging and its not lighting up at all no matter what i do- it may be the plug itself who knows!..help!
  • Anonymous Feb 20, 2009
    same problem here.. it ticks me off! sometimes it will charge and most of the time it will not.
How to charge new battery in my laptop
as i do not know what laptop we are talking about here i asume its not a notebook
if it is the time is slightly lower (6-8 hours)
a normal lap top 10 - 12 hours.
some super batery laptops come with an own (long) guide how to keep the batery alive.
to keep the batery alive a long period of time charge it from 50% not when its at critical.
If u can take out the batery when you are using cable and its fully charged it also has a longer life time. or just take out the cable when its at 100% and recharge it when it gets to 50%
dont have your computer in the lap it can over heat the computer/batery and the lifte time gets even lower.
Aug 24, 2011 | Dell Inspiron B120 Notebook
Gateway MX-7515 laptop Power button would not shut off cumputer went to hibernate and now power button will not turn on computer
first you will do ..
open the laptop cover at the back..
then look for the c-mos batery.. then remove the batery bout 30 seconds then put it back..
then turn on..
reply if it not work..
Nov 05, 2010 | Gateway MX7515 Notebook
Battery not charging
Bad battery or charging unit. A volt meter can check the charger although the battery is the problem if old I think
Jul 08, 2010 | Gateway 7210GX Notebook
Battery wont charge.
does it work fine without the battery and with just the ac adaptor?
Mar 27, 2009 | Gateway MX3560 Notebook
Fujisu laptop batery not chargin
try to check if other battery is working when being charge,if the problem is in ur battery u have to return and ask for replacement fron the store where you purchased it.nobody can repair battery pack.tnx
Jan 10, 2009 | Toshiba Satellite A105-S4004 Notebook
How old is the battery? If this laptop is a couple of years old, you may need a replacement, depending on how many recharge cycles have been done.
Dec 30, 2008 | Gateway MT3705 Notebook
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Dual Monitor Support for Gateway Laptop
Search on google for does gateway software support dual monitoring.
Jul 03, 2008 | Gateway 7330GZ Notebook
Battery won't charge.
battery could be dead,standard life for laptops is 1 year
Jun 26, 2008 | Gateway 450ROG Notebook
BATERY
hi friend,
it may the battery prob in your laptop. The battery life is maximum one year or two year in most of the laptop . You must check the battery in the show rooms or any other service centers.thanks
bye
Jun 14, 2008 | Gateway MT3418 Notebook
Gateway MT6729 Notebook Logo
113 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
