Question about LG DU-52SZ61D TV
Phillips Rear-projection HDTV(replaced bulb-still have a problem)
Hello, I have a Phillips HDTV 50".
The model no. 50PL9126D/37
The picture went black and the red light icon came on. There was still sound, but no picture. After turning it off and letting it cool down, I turned it back on and had a picture for about 10 minutes, then it did the same thing.
Warranty had expired just a couple of weeks earlier.
I replaced the bulb, however, it still does the same thing.
It blinks out a code - 6 long, 5 short.
I do hear a quiet "zzzzz-zzzzz" sound in the same area where the bulb goes in (just below it) before the picture goes black.
That part # is "EUC 132d P/41".
Does anyone know anything about this problem or that part?
Maybe even where there is somewhere to look up the code?
  • 1 more comment
  • Phillips101 Dec 18, 2008
    After doing a lot of research, that part is the ballast.
    The problem I have now is Philips only sells it with the light engine and the lamp....
    $1795.00
    So I'm wondering if there is one I can get that would be suitable?
  • beanero Jan 01, 2009
    I HAVE THE SAME PROBLEM MINE DOES THE EXACT SAME CAN WE GET IT ANY CHEEPER
  • Terry Lackry Jan 23, 2009
SOURCE: TV keeps shutting down
What do you mean by bad ballast?
Posted on Jun 08, 2007
  • 40 Answers
SOURCE: Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Posted on Jul 03, 2007
ttech
  • 139 Answers
SOURCE: blinking orange light
Ride me I can help you Contact me on Live expert ttech
Posted on Jul 21, 2007
SOURCE: TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Posted on Feb 02, 2008
ladywinn
  • 5138 Answers
SOURCE: LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Posted on Aug 15, 2009
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
Where is the power board for a phillips 50inch model #50pl9126d/37
Hello
As far as the lamp stays lit for a few seconds, all other voltages comes to the lamp and inverter board are OK. If the lamp has reached its life time, this type of fault can occur.
Feb 16, 2012 | Philips 50PL9126D/37B 50" DLP TV
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
Have a phillips 50pl9126d/37 put new bulb still no piture or sound
bearsdis,
I have a tip at http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which explains the troubleshooting procedure and where to get any parts that you may need.
Thanks for using FixYa and for the great rating.
hardrocko
May 26, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise...
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Dec 11, 2009 | Philips 50PL9126D/37B 50" DLP TV
TV tries to start up but red bulb indicator comes on, no picture
In this case we would need more specifications. discountdashmerchantdotcom
Jul 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
LG DU-52SZ61D TV Logo
284 people viewed this question
