Question about Sony Playstation 3 (PS3) Console
No display no audio
I was playing game and tv went out the playstation was set to the HDMI setting but when i hooked it up to another tv with audio video jacks i get nothing is there a way to reset the ps3 without being able to see screen
    Problem Solver:
  • 12 Answers
Hard re-set the unit by pressing and holding down the power button (front panel) from the off position for at least seconds. - it will beep 3 - 4 times
Posted on Dec 17, 2008
  • 33 Answers
PS3 is The amazing device by sony but it has some common problems like Audio, Display problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog.
Posted on Mar 06, 2009
My PS3 only has audio and no video when I play games and DVDs. This is through a HDMI cable. Am I missing anything?
Check cables again Also setting for tv if set higher then max resolution tv wont display hold power button til system beeps and then shuts off to reset turn system back on with both supplied cable and HDMI connected and go between both settings to adjust HDMI if you have turtle beach headset connected for Sound to go through both tv and headset Audio output must be set to Multi output set to ON headset will be downscaled to Channel 2
Jul 30, 2010 | Sony Playstation 3 (PS3) Console
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
I had my ps3 hooked up through a HDMI plug and I swithed tv's, now I have no video with the HDMI plug or the red, white, and yellow. Please help!
Hi, The settings on the PS3 are sending the video signal throught the hdmi port. Either go through the XMB via sys settings, display settings,or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via hdmi as well.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Hdmi doesn't work
Make sure everything is pluged in correctly and the Playstation 3 is on stand-by. The using the power button on the console hold it for about 5 seconds till you hear two beeps. And this will reset the display settings.
Don't hold it to long or it will go on stand-by.
Also try reversing the ends of the HDMI
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will work on the rca hookups but not on the hdmi hookups
When you hooked up the HDMI did you go into display settings and change all the PS3 settings to HDMI instead of AVI? I thought my HDMI wasnt working, just a blank screen but I could hear the sound, then it hit me..... change the video and display settings to HDMI and poof, there was the pic. lol
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video
This happened to me a few years back so I apologize if it's not 100% accurate. If you can get it to work on another TV, go ahead and connect it to that, and go in to the settings to select the video input. If it's connected through an HDMI cable, then it will probably be set to HDMI. Change the input here to whatever cable you used in the living room. You will have to power it off at this stage, but when you connect to the other TV it should work.
Mar 14, 2017 | Sony Playstation 3 (PS3) Console
My ps3 won't display in HDMI
hold the power button till it restarts , this should set your ps3 to the correct hdmi res.
Dec 23, 2008 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Sony Playstation 3 (PS3) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
