Question about Samsung SGH2100SGH600V300 Unlock/Unlocking Code/Codes Cellular Phone
Instinct wont turn on
Just keeps loading and loading never turns on, something must have happend during a software update
  • Anonymous Feb 05, 2009
    Same problem I've no idea what to do
    Brigadier General:
  • 7,752 Answers
Try *2767*3855#
Posted on Dec 28, 2008
Never done an update but phone keeps turning on and off not loading
This is called a loop virus. Same thing happened to my laptop due to internet use.
Nov 25, 2013 | Sony Ericsson P1i
My iphone 3Gs wont turn on. It is jailbreaked for 5.1. Then i Accidentally press the software update for 6.1 then it turned off, and if i turned it on. It will automatically blacked out then again back to...
try and RESTORE from itunes first, it should then try and download the latest software version 6.1,this whole process might take a while depending on your internet connection so keep it plugged in to your computer..if it does load the software successfully, the good news is there is a jailbreak for 6.1 :)..just visit evasi0n.com to c if your phone is compatible with the 6.1 jailbreak
Feb 09, 2013 | Apple iPhone 3GS Black (16 GB)
Phone shut of and keeps repeating the load screen but wont turn on
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Dec 09, 2010 | Samsung Cell Phones
Phone is freezing up and wont answer calls keeps turning on and off and doing a split screen. Phone is not loading properly
If your phone freezes, hangs up unexpectedly, vibrates continuously or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
Thank You
Aug 12, 2010 | Samsung SCH-u740 Cellular Phone
Why do i keep getting errors when i try to access the internet or update my software
it seems that your gateway or server is not configure properly for your software program. normally, it is the result of your software not connecting to its preferred updating site.
you would want to check your firewall and antivirus, and try configuring your internet or network settings in your computer.
take care..
Mar 14, 2010 | Samsung Instinct Cell Phone
Emergency download on sprint instinct
Let the battery die completely, it should stop. If the problem persists, take your phone into the store, it needs to be repaired or replaced... also check for software updates.
May 27, 2009 | Samsung Instinct Cell Phone
MY music player wont work on my nokia n95
update your software with nokia pc suite software updater
Sep 28, 2008 | Nokia N95 Cellular Phone
Autoamatically loading loudspeaker option and multimedia utility.
I think your phone may need a Software/Firmware update. Before doing that, try resetting the phone:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Then update the Software (sometimes called Firmware) thus:
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 27, 2008 | Nokia N70 Cellular Phone
Stuck on nokia start up screen
Try this:
Tip! Only use one Anti Virus Application on your phone.
If the above doesn't work try another update. (it may have mis-updated).
Before updating software you should check that there's a newer version of software available.
WARNING
And obviously don't unplug the phone from the PC.
If the PC freezes during an update, you're up the creek without a paddle...
Mar 25, 2008 | Nokia N70 Cellular Phone
My nokia 6233 is dead!!!
i was instaling a themen to my nikia 6233, but it seam that memory was full. any way. the mobile was of and now its not starting any more ? only starts for few seconds and then off!!
how can i reset it ? any help ? pleas till me step by step ..i am a bit confused !!
thanks
Jan 17, 2008 | Nokia 6233 Cellular Phone
Samsung SGH2100SGH600V300 Unlock/Unlocking Code/Codes Cellular Phone Logo
42 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
