Question about Sony VPL-HS51A / VPL-HS60 Multimedia Projector
Sony hs 51 problems
I am expieriencing a problem with my projector. when i turn it on i get two solid lights on the machine temp/light and fan cover light and the power/standby button is red instead of green. any suggestions? no picture or light appears from the bulb. i tried unplugging and replugging the unit . thank you.
SOURCE:
tvtechnician
  • 105 Answers
SOURCE: Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Posted on Oct 30, 2007
SOURCE: FAN/TEMP light is flashing
maybe there is a problem with the lamp (bulb)
Posted on Jan 27, 2008
  • 27 Answers
SOURCE: Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Posted on Feb 26, 2008
dhiman
  • 115 Answers
SOURCE: sony hs 51 projector problem
open the lamp cover if the power indication comes and check the connectors of cover sensors. also check and service the complete unit by disassembling all the cards & connectors. Lamp life also has to check.
Posted on Mar 29, 2008
SOURCE: Projector won't turn on, Lamp/Cover light on
This is a known fault with some early HS10s. There is a sony tech bulletin (30-2003-123) details the fault. an earlier bulletin (30-2003-032) claims this affected all models but gave no solution, other than wait for unit to cool down! :-/
30-2003-123 notes that models 10,001-16,708 were affected. I worked around the problem by setting high altitude mode which improves the cooling enough not to fault. No problems during regular use since I did this 6 years ago. Official fix is to replace the lamp cover assembly unit (X-4041-024-1) with unit (X-4041-024-2)
The fault is caused by deformation of the cover assembly due to increased temperature which causes a microswitch to indicate the cover is not installed correctly. I read about someone solving this by placing a matchstick between the cover and switch!
Simon
Posted on Dec 08, 2009
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Dec 05, 2016 | Office Equipment & Supplies
Oct 30, 2007 | Sony VPL CS1 Multimedia Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
When the projector is turned on, the green light
Sir it seems air in out problem.Clean all air filter or open lamp cover and give air pressure using with air blower or vacuum cleaner
Feb 25, 2010 | Sony Cineza VPL HS2 Multimedia Projector
Power up
Hi mick1907
Take out your lamp and check for any irregularity like marks or discolouration.
If there is no visible damage - put back the lamp and take of the top cover - start the Projector and check if all your fans are running - that is if the machine starts at all.
If the unit doesn't start up at all you will have to replace the Mainboard.
Apr 24, 2008 | Sony VPL CS2 Multimedia Projector
Sony hs 51 projector problem
Mar 21, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Jan 25, 2008 | Sony VPL CX1 Multimedia Projector
Sony VPL CS5 Multimedia Projector Problem
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Temp/fan light
Hi...  PLZ Help For sony projector vpl-sc50m
 Temp/fan light problem,
How to Stop light.....
Urjant.....
               Reply...
Feb 27, 2007 | Sony VPL SC50 Multimedia Projector
Sony VPL-HS51A / VPL-HS60 Multimedia Projector Logo
52 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
Paul
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
