Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I am searching for a front speaker bezel because some how ours got broken from the move. I am not sure if that is the proper name for it but it covers the speaker in the front of the wd-52525 52" dlp. Any help would be greatly appreciated.
  • 41 Answers
Try the source, www.mitsubishi-tv.com or parts dept. 800-553-7278
Posted on Dec 21, 2008
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Dec 02, 2012 | Dell Inspiron 620 ST Desktop Computer...
How to remove the screen from the y510
The thin plastic 'frame' in the front of the LCD screen, is the Display Bezel.
Goes by many names. Display Bezel is used by HP.
Display Mask, LCD Bezel, LCD Panel Bezel, and LCD Front Bezel, are a few other examples.
Lenovo/IBM uses LCD Front Bezel.
Lenovo doesn't show an HMM for the IdeaPad's, other than for the S9e series, and S10e series, (Notebook), plus the A1-07 series. (Tablet)
(Hardware Maintenance Manual)
http://support.lenovo.com/en_US/SupportSearchResults.page?searchText=ideapad+hmm
(An HMM is a Service Manual)
I also see there are no guides posted by users.
Therefore we'll have to 'wing it', using my years of experience with repairing laptops, and you as the tech.
1) Do you see any screw covers on the LCD Front Bezel?
May not be the usual synthetic rubber covers. May be plastic, and the same plastic, and color as the LCD Front Bezel.
Example,
http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
Scroll down to the photos in Steps 1 and 2.
Also note the 'seals' on the side of the Display Assembly, shown in Step 2 photo.
We'll start with this.
2) Haven't worked on a Y510, and perusing the internet; it seems no one has found a solution, for removing the LCD Front Bezel off of an IdeaPad Y510.
{ ALL power removed before beginning. Remove the AC adapter
(Charger), and Battery }
3)
A) There is no sticky double-sided tape holding it on.
B) Can't simply 'pop' it off, as with other Display Bezels, that do not use Philips head screws to hold it on.
[ For all Display Bezels, (Other than this baby, perhaps), there are locking tabs on the outside edges of the Display Bezel.
These match up to snap locks, on the inside edge of the Display Cover. (Top cover of laptop)
When the Display Bezel is removed, the locks snap loose ]
C) I suggest remove the screws which hold the Display Assembly to the laptop, and see if at the bottom of the Display Assembly, there are screw covers, or just screws, to remove.
If there are, and no other screw covers/screws to remove, the LCD Front Bezel should pop off.
This is what I mean by pop off,
http://www.insidemylaptop.com/replace-screen-on-lenovo-g560-laptop/
Step 2 and 3.
{ The laptop is made by Wistron. (Philippines) One of the three major laptop manufacturers, that makes laptops for ALL laptop brand manufacturers.
Such as Acer, Compaq, HP, Lenovo, Toshiba, Asus, you name it }
Post back in a Comment.
Regards,
joecoolvette
May 06, 2012 | Lenovo IdeaPad Y510 Notebook
Our HP G60-120US display works properly on start-up and in certain positions. But if the screen is moved slightly, the image will begin scrolling rapidly an uncontrollably. It sometimes works to move the...
It sounds like it's a loose wire. Your best bet would be to take it apart and take a look, that would also give you a good idea if there's something broken in there.
Check your bezel for screws and take them out. Usually they're underneath little cushions, so you'll have to peel them off. Take out the screws, then you should be able to use a screwdriver to pop the bezel off. It's kindof difficult, because the snaplocks are tight. Try to be forceful yet gentle (oxymoron, I know) so you don't break too many of them. They're fairly robust, I don't think I've ever broken one, but you want to be careful anyway. Once you have the bezel off, you should be able to take a look at the wires and cables to see if any are broken, cracked, or loose. You may also need to take off the top cover of the PC to check that as well. Usually this is held in place by screws on the bottom of the laptop, as well as more snaplocks.
There is a very good instructional for taking everything apart complete with pictures located here.
Jun 16, 2011 | HP G60-120US Laptop
Sound is only coming out of the left front speaker, no sound out of the fight front middle, back left and right and sub wolfer
Have you checked the cables? They could be broken or not properly plugged in. If you are sure that is not the problem, then the speakers or the player could be broken, do you have another device to test the subwoofers on?
Apr 11, 2011 | Dannon Recipe Box
Internal speakers buzz very badly now. The tv was moved recently, but not batted around during move. I think the speakers are bad. Is there a way to tell for sure? Or could the speaker connection just...
the speakers are definately blown buddy they are so easy to fix..................just open the bezel up and buy some speakers that are the same size any speakers will work as long as they fit inside the tv or another thing you could do is buy a cheap surround sound system
Feb 16, 2011 | Samsung LN37C550 37 in. TV
I have broken my front screen bezel from the left end corner of the hinge
ASUS screwed US buyers of this lcd bezel for UL30A. I have been searching for the part for 7 months. I even purchased the part at asusparts.eu. After 2 months I had to request a refund. One ebay user sold me theirs for $47 after they searched for the part for a year. Now I need two bezels.
Aug 23, 2010 | ASUS UL30AX5 (884840506003) PC Notebook
Bad sound from laptop speaker
To change the speaker, you would have to take apart the whole laptop because top bezel wouuld need to come off. As far as replacing the broken LAN port, you would need the exact LAN port. Meaning you would need to unsolderr the old LAN port an replace it with the new working LAN port. Either way you would have to take the laptop apart and to take off the top bezel.
Apr 19, 2010 | IBM ThinkPad A21m 2628 Notebook
How to replace front cup holder - V40. I have the new cupholder to replace the broken one. But I Need instructions on how to take the broken one out and replace with the new one . Looks like radio module...
hy!You can pull off the panel what is over the bezel,and there is two screws.Pull off the radio and there is 3 screws.And now you can pulloff the bezel. (bezel-radio holder...
http://cgi.ebay.com/ebaymotors/2000-volvo-s40-v40-radio-bezel-cup-holder-_W0QQcmdZViewItemQQhashZitem19bc67491cQQitemZ110535067932QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Aug 13, 2009 | 2000 Volvo V40
The green plastic harness that supports the power button on the front bezel of the Dell Optiplex 170L is broken. I am looking for several of these parts so that we can repair in our office.
Unfortunately the only way to get a replacement bezel for a Dell desktop is to contact technical support. If I remember correctly the cost is about 30 bucks for the kit unless youre under the service warranty still than it is free. Don't quote me on the price I'm going off of memory from about 2 years ago when I worked there so the price may have changed.
Jul 15, 2009 | Dell Computers & Internet
2000 dodge intrepid driver door latch broken. When we take the door apart, there is a plastic piece that broke that attaches the handle to the rod that pulls the latch. It does not look like there is an...
We purchased a door latch to replace ours from Dodge. It came with instructions as follows:
Instruction Sheet
Front Door Handle/Bezel Replacement for LH
1. Remove the front door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
2. Place door trim panel on a clean work surface. Drill the mounting bosses' heat stakes, which attach the existing door handle/bezel to the panel, with a 21/64-drill bit. Take extra care to only drill in the center of each heat stake.
3. Remove existing handle/bezel from trim panel.
4. Clean the back of the trim panel of plastic fillings.
5. Seat the new handle/bezel into location.
6. Place the push nuts onto the handle/bezel bosses.
7. Use a 10 mm socket to install the push nuts all the way down on the mounting bosses to secure the handle/bezel onto the door trim panel. Using a wiggling side-to-side motion may be helpful.
8. Install the lock switch from the original handle/bezel to the new door handle/bezel.
9. Reinstall the door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
Hope this helps.
Jul 02, 2009 | 2000 Dodge Intrepid
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
