Question about Ricoh Aficio 450 Copier
Have a ricoh aficio 450 and there is error code sc 623?
    Problem Solver:
  • 19 Answers
1. With the machine turned off. Go to the back of the machine and disconnect the cable that goes to the paper deck.
2. Turn on machine.
3. Turn off machine.
4. Reconnect the cable.
5. Turn on machine.
6. If problem continues you need the BICU
Posted on Dec 24, 2008
  • 162 Answers
The BICU cannot communicate with the paper tray unit properly.
· Poor connection between the BICU board and the paper tray unit main board
· Paper tray unit main board defective
· BICU board defective
Inspect the cable that it connects the paper tray unit.
Posted on Dec 07, 2009
    President:
  • Ricoh Master
  • 990 Answers
Dear sir; Happy holiday, the error code you bring out the means " communication problem between BICU and paper tray unit, it may be can be reset,the procedure as follow;
1, press "clear mode"( the c in the diamond).
2, enter107 then press and hold down "stop/ clear" key
3, when you enter the sp mode turn power off 5 second turn back on could you tell me what's resolve coming out.
4, if the resolve coming out is negative, go behind the machine check the connector
5, please let me know the resolve.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
Sc 322 for RICOH AFICIO 2045
That is a LASER error code.
It can be just toner dust because that error is a bad communication between the laser synchronization detector board and the LD unit.
Sometimes the dust of toner goes to the laser and causes this error.
Try to clean the laser unit. Maybe that work
Feb 24, 2011 | Ricoh Aficio 450 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
ERROR CODE SC329 IN AFICIO 450
Laser synchronization error
The main scan synchronization
detector board cannot detect the laser
synchronization signal for more than 5
consecutive 100 ms intervals
I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Jun 25, 2009 | Ricoh Aficio 450 Copier
Error code sc 387 on my Ricoh Aficio 4006
You'll need a tech to run a diagnostic mode to find the exact cause...could be development problem, Transfer belt, ID sensor, etc
Feb 22, 2009 | Ricoh Aficio 450 Copier
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
343 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
