Question about FIC VA 503A Motherboard
Jumper settings for an AMD 550 mhz K6-2 chip.
I have a FIC VA 503+ motherboard and need the Jumper settings for an AMD 550 mhz K6-2 chip. I also need to know where I can get an ATX power switch for an ATX power supply for this board.
    President:
  • 2,351 Answers
If you still have your manual, see page 19. Set CPU External bus frequency (100MHz) as shown & CPU to bus use 5.5x = 550MHz.
You can download the manual here:
http://www.fic.com.tw/support/download.aspx?dl=motherboard%2fmanual%2fsocket7%2fva-503%2b%2fva-503%2ba4sh.zip&title=va-503%2ba4sh.zip&info=manual
There seem to be more setting after going over the manual.
Any of these power supplies will work with the FIC board. All come with the 20-pin ATX main power. Some come with 24-pin power connector that you just do not use.
As far as finding a power switch for an ATX power supply try looking to a Good Will store. Most places have old PC parts for sale cheep. or try here: http://www.trianglecables.com/atxcaspusbut.html
http://www.directron.com/switchat.html
Good luck skivvynine!
Hope you find all this helpful.
Mike
Posted on Dec 18, 2008
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Do I plug in BOTH the 20+4 ATX power connector AND the 8 pin 12V connector on a gigbyte MB (MA790GPT-UD3h)?
Hi
You only need to plug the 20+4 ATX power connector and how about the 8 pin 12V connector? Well that is use only for legacy type of motherboard that use to require it.
Hope it helps..
Thanks for reaching Fixya
Apr 03, 2010 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Just installed a new motherboard model MSI 790FX - GD70 and new ram and cpu to go with it. plugged everything in and check all the connections. When we turn on the computer all the fans start and all the...
check the cable connections initially
Remove the power cord from the cpu
Remove the cmos battery and reset the bios by changing the jumper which is present to reset bios in motherboard.
Place the jumper as if it was present already
Insert cmos battery and switch on the computer
Mar 04, 2010 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
No monitor
Try this, reset the CMOS, but make sure that the power if fully turned off and the power cable connected to the power supply is disconnected. Change the jumper settings of the clr_cmos from 1-2 to 2-3 for approx. 10 secs. then return the jumper to 1-2. the locations is encircled on the image below.a55d1a2.jpg
Hope this helps.
Sep 26, 2009 | EliteGroup ECS A780GM-M3 AM2+ AMD 780G...
Ax4per with 1.8GHz does not recognize new 2.8GHz processor. Socket 478. BIOS is current. Is it not plug and play?
Does it POST and can you get into the BIOS? You need to set the FSB to 133MHz and the Ratio to 21x.
(I am assuming you did install the CPU correctly and installed the fan.)
If you can't get into the BIOS, you may need to reset it using JP14 on the motherboard.
Turn OFF power. Remove the AC power cord. Hold the power button in for 5 to 10 seconds. (This is done to discharge any capacitors.) JP14 normally is on Pins 1 and 2. Place the jumper on Pins 2 and 3 for approx. 10 seconds. Then place it back on pins 1 and 2. Connect the power cord and turn it on. This will set all the BIOS settiings to default and you should be able to set the FSB and Ratio.
Do you have a manual for the MB? you can get it from:
ftp://ftp.aopen.com/pub/manual/mb/ax4per/ax4per-ol-e.pdf
Thanks for using Fixya.
Wayne
Sep 10, 2009 | AOpen AX4PER 845PE P4-533MHz...
I CAN UPGRADE MEMORY IN MOTHERBOARD FIC AM35, TO DDR (2)512M 444MHZ
Hey,
Yes, here are the details
Memory Max Supported RAM2 GB Memory TypeDDR SDRAM Supported RAM Speeds100 MHz · 133 MHz Number of Memory Slots2 x 184 Pin DIMMs Let me know if you need anything else. Thanks, Ekse
Feb 18, 2009 | FIC AM 35 Motherboard
Ga-k8vt800m motherboard specs..
First, remove all power from motherboard, including the Power Supply ATX plug. Then remove ram and all PCI and PCI-E / AGP (Video) cards even network cards... Let it sit for about 5 minutes and then plug in the necessities: RAM, Video Cards and if nothing works repeat the process but alternating ram slots and ram.
Dec 10, 2008 | Gigabyte GA-K8VT800 Motherboard
I have a FIC VA 503+ motherboard in one of my computers. It has a 300 MHRZ AMD K6-2 processor in it right now. I would like to know the jumper settings for a 550 MHRZ processor. I would like to give this...
Posting pics on here is difficult. Fixya reduces them down so you can hardly see to read, so let me try to tell you.
CLK to 100 Mhz
CLK1-Pins 1 and 2
CLK2-Pins 1 and 2
CLK3-Pins 2 and 3
Multiplier to 5.5
FREQ1-Pins 1 and 2
FREQ2-Pins 1 and 2
FREQ3-Pins 2 and 3
Don't forget the CPU voltage jumper. If you comment back with the voltage I can tell you that also.
If you would prefer, I can email you scans of the pages you need. (I already scanned them. It's just that posting them reduces them too much to see clearly.)
BTW that was a good MB in its time. I had 2 of them. Still have one using a 500MHZ AMD running Windows XP Pro. It's a little slow though. :-)
Nov 18, 2008 | Computers & Internet
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
Hard drive recognized as slave drive
You probably need the change the jumper on the hard drive itself. The jumper looks like a thin little cap that covers a set of pins on the back of the hard drive. You should see it next to when you power supply connects and most drives will usually have a diagram on how to change the jumper from a slave to a master.
Sep 09, 2006 | Cornerstone FIC VA-503+ Socket 7 AT...
FIC VA 503A Motherboard Logo
753 people viewed this question
Top FIC Computers & Internet Experts
David
David
Marvin
Marvin
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
