Question about Dishwashers
My 12 year old daughter accidentially put dish liquid in my dishwasher instead of dishwasher detergent. What do I do?
  • 247 Answers
Can't see this doing too much harm in the long term.
Biggest problem is likely to be that it will froth a bit.
Suggest you run the machine empty on a "rinse and hold" cycle a couple of times. Stand by with a cloth and bucket, so that if the machine does froth up, you can mop up anything that seeps out before it makes a mess on the floor (watch the waste water outlet at the back as well as the front door.
Question: How on earth did you get your 12 year old daughter to put anything in the dishwasher in the first place - it's all I can do to stop mine leaving dirty crockery in her bed!
A.
Posted on Dec 17, 2008
Can I use dishwashing liquid in the dishwasher
I would say definitely NOT to the dishwashing liquid! Would create way too many bubbles.
Feb 25, 2013 | Colgate Dish/Dishwasher Detergents : Ultra...
Leaves a white soap residue over the dishes, the dishes are scratched. New Kitchen Aid model KUDS50FVSS4 just purchased one month ago and it's performance was not as good as my old ( 15 years) GE. I have...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;'
Apr 25, 2011 | KitchenAid KUDS50FVSS Builtin Dishwasher
Can liquid detergents be used in a dishwasher?
Only dishwasher detergent can be used in a dishwasher. Some of them are liquids. Regular liquid detergents such as dish detergent or laundry detergent is too sudsy and it will make so many suds that they will be all of the dishes and the floor if used.
Mar 03, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
I have a Maytag dishwasher that is just over a year old. I still have suds in the bottom when it is finished. What could be wrong?? I have tried liquid vs powder detergent. The dishes are clean and there...
You may want to cut back on the amount of detergent you are using. Your water may be softer than what the detergent manufacture has set there formula guide lines at. Scott
Apr 21, 2009 | GE Nautilus 24" Built-in Dishwasher
The top rack is not longer getting clean
Using liquid detergent is the worst detergent to use. One possible solution to your problem could be as follows...pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. May need to do this several times (3 to 4). This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel, no liquid and no tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Liquid dish soap in the dishwasher
You will get some sudsing, but just soak up what you can with a towel and then run 1 or 2 cycles and you should be OK.
Mar 24, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
