Question about SansuiS2001 20" TV
Line in the middle of screen
The television is black at the top and black at the bottom. There is a line in the middle of the screen. I can hear sound on the televisin and can see there is a picture it just isn't full screen. The television I have is a sansui mts stero. It wasnt listed on the screen so I just picked a standard tv to discuss my problem
    Novelist:
    Champion:
  • 236 Answers
You have a bad component in the vertical circuit of your set. If you hit it on the back of the cabinet with your hand which will "jar it" and the picture flashes back on then you have loose connection. If nothing happens then the vertical circuit has a bad component most likely the Output IC. (Chip) Stargazer
Posted on Apr 10, 2007
I bought an LCD Samsung 3 years ago and about a year ago a thick black line appeared in the middle of the screen. Can this be fixed at home?
check if the lines appear on different inputs or source like hdmi,av,pc, if it happens on a different source then theres a problem with the lcd screen it needs to be fix.
Dec 26, 2014 | Samsung Televison & Video
Black line through middle of emerson led tv screen
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Apr 23, 2014 | Emerson Televison & Video
My Panasonic HDTV has sound but no picture
I have a question : Is the line a faint band top to bottom towards the middle or to the right of the screen?
This was a fairly common problem if you can confirm it?
Nov 13, 2011 | Panasonic PT-47WX53 47" Rear Projection...
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Black line in middle of panasonic plasma screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Oct 13, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Aug 06, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
SansuiS2001 20" TV Logo
192 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
