Question about Lasko 5365 Ceramic Compact Heater
Heater does not come back on
When the heater reaches the desired temp. and then shuts off, it does not go back on automatically.
  • Anonymous Jan 07, 2009
    heater does not turn back on even though there is power, the heater just beeps but nothing happens
  • Anonymous Jan 17, 2009
    Mine's doing the same thing.. it's so cold here, please help!
I found that if I unplug the heater from the power outlet for about 3 to 5 minutes, it goes back to normal. Ive had my heater about 1 year, and have successfully done this twice. Hope this helps~!
Posted on Feb 08, 2009
Does this model shut off automatically when the desired room temperature is reached or does it function on a low medium high type of thermostat that continuously runs? IR 3 0 p m d g - 1
if it is an inverter type air conditioner ( make not indicated) the unit runs continually but the compressor delivery is reduced thereby reducing the load on the motor
as the room warms up again the compressor starts to pump more gas to keep the room at the desired temp setting
older types shut the compressor down and restarted when the high temp was reached
Jan 19, 2018 | Heating & Cooling
How do I fix the heater? The igniter will not stay on long. The heater never reaches desired temperature.
Try turning it off and unplugging it for 30 seconds. If that doesnt work, some people I know had to melt ice from their vents with a blow dryer. If not call a technician. Error codes should be in the manual.
Feb 24, 2015 | Rinnai Toyostove Direct Vent Heater: Laser...
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Water Temp
Sounds like the thermostat is bad on your heater.
US Parts Center
May 03, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Manual Hph15led
1. Plug unit in
2. Press Power button once - small dot appears on LED screen
3. Adjust desired temp with + / - buttons
4. Press Power button again to set time
5. Adjust desired time with + / - buttons
6. Adjust power output level with Mode button
Has anyone had the probelm with this heater (HPH15LED) that it doesn't continually turn back on to maintain a constant temp? I find it reaches the set temp and then doesn't come back on??
May 02, 2013 | Heating & Cooling
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Apr 20, 2009 | Pentair Mastertemp Heater
Lasko 5365 Ceramic Compact Heater Logo
336 people viewed this question
Top Lasko Heating & Cooling Experts
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
