Question about JVC GR-SXM260U Camcorder
Lost my manual
How do i get to menu to change dates/speed for camcord
DatelTime Settings
1) Set the Power Switch 4D to "1M!" while pressing
down the Lock Button (I) located on the switch.
2) Press the MENU Wheel 0 in. The Menu Screen
appears.
3) Rotate the MENU Wheel 0 to select
"~TO SYSTEM MENU" and press it to display SYSTEM MENU. Rotate the MENU Wheel 0 to select "~NEXT" and press it to display the next page.
4) Rotate the MENU Wheel 0 to select "DATE/ TIME" and press it. The DATEITIME Menu appears.
5) To set "YEAR", "MONTH", "DAY" or "TIME" (hour/minute), rotate the MENU Wheel 0 to select the desired item, and press it. When the setting begins blinking, rotate the MENU Wheel o until the correct setting appears and then press it. The setting stops blinking.
6) When none of these settings ("YEAR", "MONTH", "DAY", "TIME") blinks, rotate the MENU Wheel 0 to select "~EXIT", and press it. The Menu Screen reappears with the highlight bar on "~RETURN".
7) Press the MENU Wheel 0 in to close the Menu
Screen.
. To display the date and time in the camcorder's display and on a connected TV, see DATEITIME
DISP. (U pg. 21) in SYSTEM MENU.
. The date/time cannot be stored in memory if the built-in clock battery runs out. Consult an authorized JVC dealer for replacement, or set the date/time as necessary before you start shooting.
Posted on Feb 19, 2009
How do I reset camera to original state?
Have you removed the batteries to try to reset it? The manual should help. If you lost the manual, you can get one online, Google the "make, model and manual" and you will find a .pdf file of the manual that you can save to your computer.
Mar 07, 2015 | Samsung HMX F90 HD Camcorder, 5 Megapixel,...
Set date time display
The Date/Time command is in the DATE/TIME SETUP menu. See page 81 of this manual:
Oct 20, 2013 | Canon FS100 Flash Media Camcorder
How to change the date and time
According to manual, press the Menu button. Then press the right side of the big button with OK in the middle. This will highlight the setup menu (the wrench and hammer icon). Press the down button (lower part of big round button) to highlight date and time. Press up, down, right or left of big button to move cursor and change values. The press OK. Press Menu again to exit.
May 09, 2010 | Mustek DV526L Camcorder
How do you put the date on recording
Page 25 of user manual - see link below - explains how to super impose the date and time on the image
Apr 07, 2010 | Sony Handycam DCR-TRV265E Digital...
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
Changing to correct date on camcorder
To change / reset date and time touch on lcd screen, HOME > SETTINGS > CLOCK / LANG > CLOCK SET and set the date and time.
Above said is mentioned in user manual of DCR-SR42 and you can download it from Sony Support.
Dec 03, 2008 | Sony Handycam DCR-SR42 Camcorder
Changing Shutter Speed
Hi - You can download the manual by clicking the link underlined in blue below:
NV-DS38
See page 24:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 23, 2008 | Panasonic NV-DS38 Mini DV Digital...
Jvc gr-d370as - help connecting to Mac - Date and Time Setting
hi there on the front there is a small wheel turn your switch to the letter (m) then press down the small wheel on the right of machine, this will give you the menu so you cant change date from that hope that helps
mike
Jun 23, 2008 | JVC GR-D20EK Camcorder
HOW DO I SET DATE & TIME-ALSO GO FROM SP TO SLP
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
JVC GR-SXM260U Camcorder Logo
510 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
