Vizio 42 in. LCD TV Logo
shar Posted on Aug 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upsdie down reversed tv image - Vizio 42 in. LCD TV
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 11, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292596
Points
3377
Resort to factory settings and try.
Samsung lcd tv with double image on screen
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
1helpful
2answers
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
2answers
Will turning your television upside down damage your television?
No it will nNo it is not. In fact some televisions are designed with this in mind. Usually this is done with smaller televisions that will be mounted. On those televisions there will be a picture flip or reverse image/invert image setting. I have spoken with bewildered seniors with upside down pictures and advised them to simply press picture flip until their image is right side up again. There are some customers that mount their televisions in bathroom mirrors or on the ceiling, under kitchen counters, and etc. who have found this to be most helpful.
I think I have inserted a CD in upsdie down, the computer will not read it and i cannot eject it, is there any other way to eject the cd
Most CD/DVD drives have a small hole next to the eject button. If you take a paperclip and press it into that hole it will manually eject your disc.
Hope that helps. If it did please leave positive feedback.
2answers
Asus K50I model laptop webcam image reverse
Most problems with reversed or up-side down webcam images are caused by the wrong device driver. Try reinstalling the webcam driver, or find the right one.
7helpful
2answers
Inverted image
All images in astronomical telescopes are upside down and reversed-- this is normal. There is no up or down in space. Reversing the image just adds more GLASS to the light path.
1helpful
Samsung D900i Screen image sometimes reversed. Screen goes blank and image moves randomly
Hi
I can tell you how to solve the reversed image. With the camera running look on the side of phone where the up/down volume keys are. If you press up button you will notice image on screen change. I think the down button inverts the image? Up or down this should correct your inverted image problem.
With regards to people experiencing lines and blacked out screens this appears to be a phone fault.
Jul 15, 2008 • Cell Phones
Image on flip screen upsdie down
There is a vertical position switch on these models. Probably needs to be replaced.
JVC HD-52Z575
You both need to have a service center come out and reset the TV using the reset jig. This will correct the reverse image problem.
1helpful
Display on moitor
You will need to go into the display adapter from the control panel and select rotate display. Some monitors have are configurable for ceiling mounting for class rooms and other public viewing.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
