Question about Krups 288 SensoToast Compact 2-Slice Toaster
My Krups model 288 toaster won't always latch down.
Toaster latch lever sometimes doesn't stay down. When it does, it pops up after a short time.
  • 3 Answers
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Posted on Mar 27, 2007
Variation for FEM 231
Ingbin's useful description has to be enlarged and adjusted for the FEM231 which is much more complicated to dismantle. I have reposted ingbing's commentary with variations
Clean the toaster first. Remove the crumb catching plate that slides out from the lever end. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray.
1. Unscrew the six screws located in of the bottom base. On my toaster, 4 were Phillips heads but two were Allen screws (a booby trap to foil the initiated?). Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later.
2. Prise off the smaller adjustment knob. The indicator pointer end has a lip you can use for leverage. To take off the main action lever, first prise off the “stop” button. There is a third hole in between the two holes for fixing screws you have just removed at the knob end. Using a thin screwdriver reach up through this hole to the base of the stop button and lever it out.
The action lever is held in by two grub screws. Turn the lever all the way to the left and unscrew the small grub screw. It comes right out and you have to catch it and keep it. Then turn the lever all the way to the left and take out the second screw. Then take off the metal lever. One segment of the white disc beneath is loose. It needs to be slid out otherwise it will become lost within the body of the toaster. The chrome fascia will now come away.
3. This exposes one of the circuit boards which can be unscrewed and removed.
4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to its original position.
4. If you need to reach the second circuit board and the lever mechanism itself, you have to continue by removing the main cover. It will now lift out and can be carefully manipulated off. You then have to remove the black unit in which the turning mechanism sits, first the top part which will clear the white disk. Then, from the top, unscrew the four retaining screws and lift the unit out.
5. Re-assemble the toaster by reversing steps 1 to 4. You will need a magnetic screw driver or some substitute to get the grub screws back though the whole.
Shanks
Posted on Oct 13, 2008
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Waring pro toaster oven: the toaster part spring would not stay down. How to repair?
Most of the time this problem is caused by a build-up of toast crumbs in the latch mechanism. Unplug the toaster oven and follow the instruction manual directions for cleaning the toaster section. Try cycling the toaster lever up and down a few times, then clean out the crumb tray again. If that doesn't solve the problem, you'll have to look for an access to the latch mechanism to clean it out and perhaps gently straighten the latch hook if needed. Note: these are generic directions for all such toasters. I can't be more specific without knowing which model in the Waring Pro line you have.
Jul 02, 2017 | Waring Toaster Ovens
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
Jul 28, 2011 | Braun HT600 2-Slice Toaster
The left side of the toaster does not stay engaged...if I hold it down it heats up but it doesn't stay down ..it doesn't catch.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
Jul 02, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
The lever doesn't stay down anymore, what should I do?
It sounds like the latch is broken. Unless you are very comfortable opening appliances and know very well what you are doing, it is best to have the toaster replaced. Check if it's still under warranty, or buy a new one.
Any workarounds to block the lever in its down position are very dangerous and a potential fire hazard. You may be able to wiggle the lever into place so it catches whatever is left of the latch, but make sure it will pop up easily when the toast is ready.
I hope this helps.
Nov 16, 2009 | DeLonghi RT200 Retro 2-Slice Toaster
My toaster will not turn off. I press the toast button, it does it's job and then pops up, but the heating elements will continue to stay on.
It sounds like the temperature sensor has malfunctioned. When the sensor reaches a certain temperature it opens the contact to the heating elements shutting off the toaster. If the unit is under warranty then take it to a repair facility for Krups. I would not allow anyone to use the toaster. If left on it could cause a fire. Take care, stay safe and good luck with your unit!
Nov 10, 2009 | Krups FEC212 Toast Supreme 2-Slice Toaster
Problem with jaipan toaster
the release mechanism contains a bimetallic strip that snaps open when a certain amount of power goes through it based on the setting. When cold, it should trap the toast loading lever mechanism. If not, it may be broken or bent. Don't work on it with power applied
Nov 21, 2007 | Krups 288 SensoToast Compact 2-Slice...
Krups 288 SensoToast Compact 2-Slice Toaster Logo
1,651 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
Irene Tulloch
Don Eagan
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
