Question about LeapFrog Little Leaps Grow With Me Learning System
LITTLE LEAPS JOYSTICK ERRATIC OPERATION
When prompted to move the joystick to make a activity selection, the joystick movement is not recognized. I have to wait for the voice on the dvd disk to tell me to move the joystick again. When I move the joystick a second time, then the system recognizes the selection. This happens on the Thomas and friends disk. Other disks seem to work okay.Could the disk be bad?
  • STANMAR725 Dec 18, 2008
    After I tried many other disks, the system seems to work okay. I think this one dvd disk is defective. This problem no longer requires a solution.
techjuli
  • 157 Answers
SOURCE: I need the little leaps dvd codes for my dvd player
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1449&p_created=1153327777&p_sid=BzNLCfWi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yODgsMjg4JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
The above link is from leapfrog and posts all of their known dvd codes. Unfortunately, yours is not listed.
Did a bit of research and it looks like the Venturer is a budget off-brand made by Alco who also makes Toshiba. So I would suggest trying the Toshiba code first (which is "57") or else calling the leapfrog customer service number located on their website.
Posted on Dec 04, 2008
SOURCE: i need dvd player codes
I don't know what brand you have, but you can download the manual as a PDF here:
http://www.leapfrog.ca/etc/medialib/leapfrog/parent_guides/pg_infanttoddler.Par.16416.File.tmp/10210_LittleLeaps_SetUpGuidepdf.pdf
Posted on Feb 01, 2009
SOURCE: Little Leaps Code for DVD
Try 52 or 000,001,006,013,014,052,068,075,111,112,113,117,118,140,141. All from the manual.
Posted on Mar 01, 2009
  • 72 Answers
SOURCE: Little Leaps DVD Code
Apex- 003
029
103
104
106
Phillips-002
004
022
027
036
066
114
115
122
123
Posted on Mar 21, 2009
SOURCE: need to know how to find the codes to set up
searched for the manual and downloaded it and read the info i needed out of it.
Posted on Dec 05, 2009
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
Why won't Microsoft Combat Flight Simulator for Windows 98 recognize my logitech joystick?
click on the joystick and then click on the properties tab
check and adjust compatibility
tick the box and move down the list to win 7 and click that ---apply and ok
it sound slike a compatibility fault or a missing driver for the joystick
Mar 15, 2017 | Logitech Extreme 3D Pro Joystick
In game characters move automatically
This movement is because of a joystick that is broken. The joystick, while in the netural position, is sending signals to the console and thus moving the character. The only solution is to pull the joystick straight out until you hear a click. If that does not fix it, then the controller is broken.
Apr 24, 2011 | Microsoft Xbox 360 Controller
Joystick registers false activity
This is a common issue with the PSPs --- the analog joystick assembly wears out and characters start moving by themselves. Replacing the part will fix the issue. The following website sells the part for $15 and installs it for $20 more:
http://store.richspsxparts.com/pspanstasre.html
Small Tidbit of info: The PSP 1st gen never came in Piano Black. Piano Black is a shiny glossy black color that started with the 2nd gen PSP. The 1st gen is more of a matte black color.
Oct 23, 2009 | Sony PSP (Piano Black)
I recently purchased logitec extreme 3d pro joystick and a user manual did not come with it. How do I get one?
Did you purchase it open-box or second-hand? If so, you shouldn't be surprised at the lack of a manual. If you bought it new, it may not have come with one.
I personally have one of these joysticks, but I bought it so long ago that I can't remember if it came with a manual or not.
Either way, there really isn't much need for a manual for this joystick. It doesn't have any very advanced features that would require a manual. It's very simple to use:
  1. Plug it in to an open USB port on your computer.
  2. It should be automatically detected by your operating system. If not, you may have a defective joystick or a defective USB port. Try the joystick in another USB port. If the problem persists, check Logitech's website.
  3. In Windows, click Start->Control Panel->Game Controllers. You should see the joystick listed. Select it and click Properties.
  4. It should open a new window to the "Test" tab, where you can make sure all the buttons work. I suggest you click on the "Settings" tab at the top left.
  5. Click "Calibrate..." and follow the prompts. It'll ask you to keep the joystick centered and press a button on the joystick (use one of the side buttons such as 11 or 12 so that you don't inadvertently move the joystick from center).
  6. Then it'll ask you to move the joystick in complete circles. Do this several times and advance to the next step.
  7. It'll ask you to move the throttle slider up and down. Do this several times and advance to the next step.
  8. It'll ask you to set the "Z-rotation," which is the left/right twist of the handle. Do this several times.
  9. It'll ask you to center it and press a button. See step 5 above.
Now the joystick should be calibrated and ready for use. If you have multiple game controllers, you may want to click the "Advanced" tab back in the Game Controllers window and make sure the Logitech Extreme 3D Pro is selected as the preferred device.
Now start whatever game you want to use it with. You'll probably have to configure what you want the buttons on your joystick to do within the game; follow the instructions that came with the game.
Pretty simple, and like I said, there are no advanced macro functions or anything like that for this joystick.
Apr 10, 2009 | Logitech Extreme 3D Pro Joystick
Game will not recognize the joystick.
If it doesnt work, then try the controller. If the controller works, then just use that. Sometimes the system does not recognize the joystick.
Mar 27, 2009 | Logitech Attack 3 Joystick
Upwardly movement of the joystick erratic and the keying slow
Just switched off for a little while and again switched on the mobile and the problem solved
Mar 25, 2009 | Sony Ericsson Cell Phones
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Jun 25, 2008 | Microsoft SideWinder Precision Pro 2.0...
Trying to Taxi
Your joystick's drivers may not be installed or installed correctly. I reccommend you go to your joystick manufacturer's website and try to find drivers for your joystick.
The flight simulator (I'm guessing that's what it is) may also not be configured correctly to use a joystick. Check in the game options to make sure that you do have joystick support enabled.
Apr 09, 2008 | Saitek (PS28) Joystick, Throttle
ST220 Joystick calibration problem
Your joystick contacts make that +cursor to make a crazy movement. You should replace that rubber contact on your joystick.
Aug 07, 2007 | Saitek ST220 (J-30U) Joystick
LeapFrog Little Leaps Grow With Me Learning System Logo
52 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
relojmesa
Crystal Turner
Level 1 Expert
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
