Question about HP Photosmart C6180 All-In-One InkJet Printer
Will not print cartridges out of date
Does anyone know where the cmos battery is on the Hp C7180 printer I was told that if you remove the cmos battery your printer will print if the cartridges are out of date. they have a date stamp on them even if the cartridge are full it will not print if they are out of date. What a waste my printer is A hp Photosmart C7180
    Problem Solver:
It's located just behind the power button near the front of the unit, on the right side (if you are facing it)
Posted on Dec 29, 2011
  • Waverly Hill Jan 01, 2012
    The information I gave is for the c7180, not the c6180.The cmos battery location for the c7180 is just behind the power button near the front of the unit on the right side (if you are facing it)
Your link does not actually link to printers.. only to HP PC's but seems to be a mis-label by HP... no surprise there.
Posted on Mar 04, 2009
My printer is the HP Officejet Pro L7580. Had the same problem with cartridge expiration date. Tried setting date backwards, but did not work. Learned that removing the battery should work. Only problem, where is the battery? Its position varies depending on the model. For mine, it is on the right side.
1) Remove the power and USB cable from the back.
2) Remove the two torx T-20 screws from the right plastic panel that surrounds the power and USB jacks.
3) Open the printer top to the second level (below the glass) and remove the one torx screw.
4) Slide the right side panel off to expose the green circuit board.
5) The battery is on the medial (toward the middle) side of the circuit board, so the circuit board has to be removed from the frame. Remove the 6 torx screws.
6) Gently pry (you may need a small screwdriver for some edges) the circuit board out. Be careful not to overly stretch any of the electrical wiring when handling the circuit board.
7) Flip the circuit board over to expose the battery, in my case, a CR2032. Pry the battery out with your fingers.
8) Fashion an insulator to fit between the terminals. I cut a disk out of an old bicycle inner tube. A disk cut from an old plastic credit card should work; just don't include the magnetic stripe! Insert insulating disk.
9) Put everything back together and test.
Posted on Nov 03, 2011
    President:
  • 2,351 Answers
I never heard of that for the C7180 all-in-one. Remove the ink cartridges. Dampen a rag with water. Slide the cartridges across the rag until you see ink. If yes, than good. Grab a couple of cotton swabs & drip a couple drops of alcohol onto a tip. Wipe the copper contacts off on the ink cartridges. Do the same to the contacts within the ink carriages. Replace the ink into the carriage.
From your computer, open Printer and Faxes. Make sure your HP C7180 all-in-one printer has a check mark next to it. If not, left click the C7180 once so its high-lighted. Than click "File" in the upper left corner of the window. Left click, "Set as Default printer". Than right click once on the C7180 & slide to & left click on Properties. In the next window click "Printing Preferences", Another window will open. Left click the "Services" tab. Click the "Service this device" button.
Than click, "Clean the Print Cartridges". When the printer finishes, click "Print a Test Page", button. (If you do not see ink on the test page than your ink cartridge are too clogged & you'll have no choice but to replace them).
Using the damp rag loosens possible clogged/dried up ink. Cleaning the contacts with alcohol removes oil from touching the copper contacts with your fingers, also removes dust. Always keep a cover over your printer when not in use. My current ink cartridges are at least 1+ year old. HP & other manufactures do use tracking software to monitor your ink cartridges in this fashion. If you remove an empty cartridge & re-fill it & replace the cartridge the software knows. Each cartridge has a tiny chip attached to it.
The internal software knows when you fill a ink cartridge & can shut down your ability to print. Forcing you to buy new ink cartridges. Below is the HP link for your C7180 printer.
http://search.hp.com/query.html?charset=iso-8859-1&lk=1&la=en&nh=10&rf=0&qs=&hpvc=sitewide&uf=1&st=1&qt=replacement+cmos+battery+for+HP+C7180+printer&submitsearch.x=2&submitsearch.y=4
Good luck timmer047!
Mike
Posted on Dec 17, 2008
HP Photosmart C7180 printer with clogged print head.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 30, 2012 | HP Photosmart C7180 All-In-One InkJet...
HP C7180 has message INK Thresholds Exceeded Do Not ship in its current condition
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
Jul 06, 2012 | HP Photosmart C7180 All-In-One InkJet...
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
HI been using this printer HP C7180 All in One for 2 years great
Hello
completely Uninstall the drivers and reinstall drivers
Go to control panel Add/Rem and remove HP Software
Go To Control Panel
Click on System - Hardware - Device manager - Printers - Right click Uninstall (HP Printer Drivers)
Reinstall the drivers from the following link
HP PS C7180
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153754&lc=en&cc=us&dlc=en&lang=en&cc=us
Jan 07, 2010 | HP Photosmart C7180 All-In-One InkJet...
Hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Feb 09, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp c7180 Photosmart Printer stopped printing legible characters
The print heads are actually located on the bottom of the print cartridges. Remove each one and inspect. If you find nothing then check under the print cartridge carrier while the cover is open and the carrier is in the service position.
Dec 21, 2008 | HP Photosmart C7180 All-In-One InkJet...
C7180 Print in color without all cartridges
You can usually print with an empty cartridge, even though the software will inform you that the cartridge is empty. Your print quality may be affected, however.
Dec 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,643 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
