Question about McCulloch FH180A Electric Pressure Washer
Cannot get McCulloch parts
I have had an on/off switch on order from McCulloch for 4 months with no availability date. My unit is model:FHH18A, s/n:08605. The p/n I need is 7022-140A02. Any recommendations as to where I can get this part, or, a replacement part from a different supplier?
  • yadayada
    yadayada May 11, 2010
    why not use a generic switch from the hardware store, ACE has a great selection, that is what I did for the same problem.
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I need a switch fo a Mcculloch FH140A or rocker parts
The switch number I found is 7022140A02 and list is 2.84. You can go to McCullochpower.com and find a dealer near you or order the part online. You can follo the links to look at the same breakdown I found for other parts
Posted on Jul 27, 2009
  • 19 Answers
SOURCE: Where can I purchase oil rings that go into the
I assume you mean the rubber O rings inside the wand. I had to replace mine as well. I had to visit several plumbing supply stores to find one that fit. I ended up taking the end of the wand with me so I could make sure the O ring fit. The ring you are after is a number 5, but you need to make sure it is thick enough to make a good seal.
Posted on Sep 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I need a manual for a McCulloch pressure washer
Your manual can be downloaded from here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2006/MOUS2006_7096H18A01.pdf
If the above link does not work start here: http://www.mccullochpower.com
Which should get you to this page where you type in FHH18A as the model number
http://www.mccullochpower.com/node7877.aspx (Use for ANY McClloch
Course of last resort.... Call them at this number: 1-800-521-8559
Thanks for choosing FixYa,
Kelly
Posted on Oct 18, 2010
Asbestos 56
  • 191 Answers
SOURCE: I have a McCulloch FHH18A
I would guess there is a leak somewhere inside the unit that is spraying water on some electrical component and causing a ground fault.
Posted on May 16, 2011
Need a new on/off switch?
They wear out. I had that happend on an h1610 "Powerwasher" brand. I replaced it with a regular switch that I bought at the hardware store or try to order a replacement online. Switches must be protected from water.
Jun 02, 2014 | McCulloch FHH18A Electric Pressure Washer
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
McCullock Powerwasher FHH18A - All hooked up, but pump won't turn on. Is there another switch/button somewhere?
look for 2 things. 1. the GFCI button on the plug, you may have to press the 'reset' button to turn it on. 2. there may be a reset button on the motor or the unit somewhere this will usually be round, and often red, but maybe black also. hope this helps
Jun 24, 2011 | McCulloch FHH18A Electric Pressure Washer
Wand
7228-H18A01
Go to this page: http://www.ordertree.com/ModelInfo.asp?Final=1&SiteID=1&Mfg=139&Model=FHH18A
Then click on the 4th link in the middle of the page with the part number above. Click "add to cart"
The list price is $35.93
Thanks for using FixYa.
Kelly
May 16, 2010 | McCulloch FHH18A Electric Pressure Washer
Small crack in the wand.
This part number is for the wand and hose assy 41 7228-H18A01 WASH MANCHINE HAND ***'Y
This is the manual I used: http://ipl.ordertree.com/ipl/604/FHH18A.pdf
It is available from this source: http://www.ordertree.com/ModelInfo.asp?Final=1&SiteID=1&Mfg=139&Model=FHH18A click on the 4th item with the part number above listed and add to cart. $35.93
The shipping fees are listed here: http://www.ordertree.com/cms/shipping-policy/14.html
$9.95 + $12/95 for Canada shipping
If this is not your model or not part of what you needed just respond here and I will get back to you. Please ensure you include your exact model number when responding.
Kelly
May 14, 2010 | McCulloch FHH18A Electric Pressure Washer
I need a manual for a McCulloch pressure washer FHH18A. Download did not work.
I need a manual for McCulloh 1600 PSI pressure washer > Its motor is working but there is no pressure
Aug 23, 2009 | McCulloch Garden
Fhh18a water flows INTO the tanks during operation.
There should be a ball and spring in the valve where you attach the soap suction hose.
Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
McCulloch M#FHH18A High Pressure Jet Washer,
On hooking up to a water source and plugging it in to an electrical outlet any attempt to test the unit is unsuccessful to include having the on/off switch in either position. With the switch in the on position pump does not operator. The last time I used the unit was July of last year and prior to storing it I did drained the hose.
May 29, 2009 | McCulloch FHH18A Electric Pressure Washer
McCulloch FH180A Electric Pressure Washer Logo
302 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
