Question about Lexmark Optra T612 Laser Printer
Printer is printing many weird characters
The characters are very odd. it prints number 2, hear and spade shapes and smiley faces and characters like Cae with carrots above the 'a' or accent mark above the e. then it also prints # and >. These characters are spread across the whole page with some blank lines in between.
ex: I put this text in a word doc: This is a test for the lexmark
when it printed, it printed: BRJN"SGVRCGGRROVGCV?OFF two times on different lines, then BRJN"SGV"RGV?OFF on a diff. line then BRJN"SGV"RGSON on the last line.
Thanks in advance for your assistance
  • Anonymous Jan 20, 2009
    My Printer is printing Different charecters which cannot be read, even when I print a test page. I use sn HP LaserJet 1022
I had this problem. It was caused by a badly-fitting parallel printer cable. I unplugged the cable at both ends, blew out the dust and re-plugged it. It then worked fine.
If that does not work for you, try cleaning the contacts with electrical contact cleaner. Clean both cable ends, clean the printer socket and clean the PC socket.
Alternatively buy a replacement cable.
Parallel/centronics cables and connectors are far more delicate than USB cables.
Posted on Feb 13, 2010
  • 37 Answers
Try deleting your driver and then reinstalling it. It sounds like the information that is coming from the computer is getting mistranslated to the printer. Usually uninstalling and reinstalling the driver with the newest version fixes these problems. Here is a link to Lexmarks driver finder. Just put the information that applys to you in the drop downs that appear and follow the instructions.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Dec 17, 2008
The box serial number
If it's an XBOX 360 look for the barcode sticker just above the AV port. The serial number is printed just below the barcode on the sticker.
The Wii: Lie the Wii on its side so the Nintendo label on the bottom is facing up. Locate the "Serial No:" bar code and read your 12 character alpha-numeric serial number.
Jan 06, 2014 | Video Game Consoles & Games
I cannot insert a 'smiley face' emoticons when composing a new email
TYPE: COLON (:) MINUS (-) RIGHT-PARENTHESIS ")"
and it should replace those 3 characters with :-)
Dec 27, 2013 | Microsoft Computers & Internet
Separator Sheets with smiley faces
Attempt to restore printer to factory defaults to cure this issue.
Sep 06, 2017 | Lexmark T644 Laser Printer
I have a swintec 8014 s and I would like to use the less than carrots and the more than carrots above the 7 and 8 on the number line. they are not the usual shift key characters, so that is what I want to...
You need to activate "keyboard II) (keyboard 2). There is either a separate KBII key you need to press OR it's a 'code' function in which case you hold down the 'code' key then press the kb2 code key, then release the 'code' key.
Feb 24, 2010 | Swintec Office Equipment & Supplies
I want to have the source codes for printing diamond shape asterisk in visual basic
I am pretty sure I got this as a homework assignment in programming class. If I had someone give it to me then I wouldn't be even the limited programmer I am now. That said, I will help, but I will not give you the full out answer.
  1. The number of stars and characters per line are an odd number to make the ASCii look like a diamond. For my example, the maximum number of characters per line is five.
  2. Create a variable called dia_star that will hold the spaces and stars. To figure out the number of spaces that should be put into each star line, use this formula:
number of spaces per star = ( max number of characters per line - number of stars) / 2
dia star = number of lines before star and "*"
print dia star
  1. --*--
  2. -***-
  3. *****
Good Luck,
NOLA Tech
Jan 30, 2010 | Microsoft Visual Basic Enterprise Edition...
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
Jul 28, 2009 | Dell 1720dn Laser Printer
Smileys for my samsung E250 mobile
Your device is only defaulted to use certain emoticons, symbols, and numbers. There is no software available that will allow you to use animated emoticons. Learn to use the symbols you have to create the smiley face you desire.
If your phone will support certain IM's, that is the only other way possible to use animated emoticons through IM. Thanks.
Mar 19, 2009 | O2 Samsung SGH-E250 Cellular Phone
Wheelwriter II characters above the numbers print incorrect.
You may have an unusual printwheel that has special char. on the P/W, or you may be in the language mode hold code and press "L" key.
DickyO
Mar 10, 2009 | Lexmark Wheelwriter 3 Typewriter
SONY ERICSSON K850I
As sms is text only, people will get text messages only. To convert the smiley-characters into smiley images, the receiver should have support for emoticons, or have a 3rd party program to translate the emoticons. As most phones consider SMS as text messages, they won't convert them to emoticons...
You could try sending a message to yourself, or someone else with a k850i...Just to try.
May 15, 2008 | Sony Ericsson W850i Cellular Phone
Crazy characters start to print when printing from pdf doc or certain websites
I understand that the printer is printing garbage when you are trying to print from internet.
Please follow the below given instructions to resolve the issue.
This issue can occur if the data send from the application from which you are printing, is using the PC-8 character set. This will produce a smiley face or garbage charters each time an unsupported escape code is sent by application. To know the character set, please contact the manufacturer of the application.
Also, you can follow these steps to disable the power managment in the comoputer.
1. Right-click My Computer, choose properties
2. Click Hardware tab, click Device Manager button.
3. Click the + next to Universal Serial Bus Controller.
4. Right-click USB Root Hub, choose properties.
5. Click Power Management tab.
5. Uncheck the option "Allow the computer to turn off this device
to save power.
6. Click Ok.
If the issue persists, follow the instructions from the below given weblink to resolve the issue.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01105&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue.
Regards,
Lawrence
Nov 13, 2007 | HP Photosmart C6180 All-In-One InkJet...
Lexmark Optra T612 Laser Printer Logo
3,227 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
