Question about Canon MV3i Mini DV Digital Camcorder
Canon MV3i When I turn the camera on (power dial in any orientation) I instantly get a "Remove cassette" message accompanied by a bleeping sound. After approx 10 secs the message and bleep stop and are replaced by an "Eject" message. I remove the cassette and then replace but get exactly the same sequence of events. I remove the cassette and replace with a new one. The new cassette works for approx 10 mins and then same sequence as previously encountered ("Remove cassette", Bleep,"Eject"). I have now tried approx 10 new cassettes and had the same problem with each.
SOURCE: Message reads eject. won't eject
Ihatecanon, Tried the steps you provided above with no luck. Then decided to gently smack the camera twice on the right-top side of the tape compartment. It freaking worked the first time. Got this idea by watching Eric Cartman on South Park... No, really. I read about this in another forum. It's a quick $150 back in your pocket. Just think. You sent the camera to their tech guys and paid them 150 to SMACK-IT :)
Posted on Sep 29, 2007
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Posted on Jan 03, 2009
SOURCE: "remove cassette" warning on ZR100
I have read that slapping the non-foldout display side of the camera a few times has worked for several people.
Posted on Apr 01, 2009
tbreeze47
  • 3083 Answers
SOURCE: Canon ZR 10 Digital Video
Usually the cassette mechanism just needs cleaning when this happens, and a camera repair or tv repair shop can clean it. You can try a dry or wet cleaner, and they're available on the net (just google it), or try
Best Buy or Radio Shack.
If a cleaning doesn't fix the problem, it will have to be serviced.
Good luck, and hope this helps.
Posted on Oct 26, 2010
MVi manual
You maybe able to download a manual from this WEB site.
http://camera.manualsonline.com/manuals/mfg/canon/dmmv3i.html
Mar 30, 2013 | Canon Cameras
Where is the power button for canon eos elan iie?
There isn't one. To turn on the camera, hold down the lock release button (just inboard of the command dial) and turn the command dial from the "L" position. To turn off the camera, hold down the lock release and turn the dial to the "L" position.
If you need a manual you may download a copy from here.
Oct 31, 2012 | Canon Photography
My Cannon ImageRUNNER 2270 is not printing the entire page. It is cutting off the top quarter of the page. I have changed the margin settings and it is not doing anything different.
Check to make sure that the paper size dial on the paper cassette is the same as the paper size in the cassette. Portrait or landscape? I don't know whether you use American sized paper but the dial Must be LTR ( front to rear orientation of paper ) or LTR-R ( Left to right orientation ). I know of no other reason for the problem.
Jun 19, 2011 | Canon imageRUNNER 2270 Copier
Copier orientation is incorrect. We print or copy something "portrait" and the result is "landscape"
Check to make sure that the paper size/ orientation dial is correct for the paper in the paper cassette.
May 02, 2011 | Canon imageRUNNER C3220 Color Copier
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Dec 06, 2008 | Canon ZR100 Mini DV Digital Camcorder
Canon MV3i Mini DV Digital Camcorder Logo
118 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
