Question about HP Officejet 5510 All-In-One Thermal Printer
Can't fax long distance now-
I am unable to send or receive faxes long distance, but can fax when they go or come from numbers in same area code- this might have started after new computer with vista system- phone company says line is fine and i can make long distance phone calls
    Genius:
  • 2,120 Answers
Do you have a DIGITAL phone service like Vonage?
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line..
Posted on Dec 30, 2008
Can receive faxes but can't send
It almost seems your HP machine is arbitrarily denying you access to long distance numbers. Try referring this issue directly to HP for an explanation.
Dec 20, 2013 | HP Officejet Pro L7590 All-in-One InkJet...
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
HP Officejet 6310 All-In-One InkJet Printer Changed home telephone system and now I can send faxes out but cannot receive?
Hi
Check the following link
CAN SEND but CANNOT Receive
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button () on the product control panel.
    2. Press 4 for Basic Fax Setup, and then press 1 for Fax Header.
    3. Type personal or company information using the keypad, and then press OK.
    4. Type the phone number, including area code, for your HP fax product, and then press OK.
  2. Dial 1-888-HPFaxme and send a fax to the HP Fax Test Service.
Jan 04, 2010 | HP Officejet 6310 All-In-One InkJet...
Why is it when I am sending a long distance fax to another state I receive a code that says G3.
There are several reasons this could be happening.
  1. Does your office allow for long distance dialing and if it does, do you need to "Dial 9" or some code before dialing long distance?
  2. Have you dialed "1" before the area code?
  3. Is the area code correct?
These are the most common reasons why you would get a long distance error while faxing. Hope you find this useful.
Nov 16, 2009 | HP 1040 Plain Paper Inkjet Fax
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Can't fax
Can you send faxes to a local number? If you can the problem is likely to be that there is no long distance carrier set up for your new VOIP service. You could also try using a regular telephone connected to the same jack as the fax uses to try dialing a long distance number, this may give you a hint as to what's wrong. You should also contact Comcast tech support about this problem, the VOIP box may not be properly configured for long distance service.
Carl
Dec 04, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Won't send faxes to 817 area code, all others OK
The recipient may have a DSL phone line, or receiving to a fax server that blocks your area code.
Oct 14, 2008 | HP 640 Inkjet Fax Machine
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Sending an international fax with a brother fax machine
I'm thinking you did not specify 1 for long distance and international calling check the TX settings for international and long distance
Aug 23, 2008 | Brother Office Equipment & Supplies
Cannot Send Faxes
Problem:
Not sending to long distance and government sites with encyrptor. Note: NG is not actually part of the Fault Code. NG stands for No Good on the Activity Report. Cause:
Not enough time to hand shake. Another cause of B5 can be a faulty Main PWB. Note: Should you wish to change the Main PWB, consult the following ETI 170535 to insure that you are selecting the correct part number. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. On speed dials and one touch numbers that the Customer is having problems with, you will have to modify the number to be dialed. What you have to do is add pauses to the end of the number. (example 555-5555 does not send to, error B0 (that is B Zero ) every time / then start adding pauses at the end of it until it works. Example 555-5555#. in some cases in Winnipeg and surrounding areas we have had to put up to 6 pauses to get a successful send. Note 1: These were to Fax Machines with encryptor devices and long distance...Avoid Call Backs. Inform the Customer of this. LEAVE instructions on how to do this. This will save your and your Customer some headaches. Note 2: Some success has been found by turning off the V34 Modem
Apr 16, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
HP Officejet 5510 All-In-One Thermal Printer Logo
383 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
