Question about Car Audio & Video
Flat battery - radio now inactive
My car battery went flat while I was waiting with the radio on waiting for someone with the engine off. Now the car radio/ cassette player won't work and the LED display just states "SAFE" instead of any radio station or mode.Can I re-set this to reactivate the radio/ cassette player?
  • sheena_l Dec 19, 2008
    It's a Seat Leon 1.6. Presumably the code can be found in car manual but I've mislaid it....
  • colmcardle May 11, 2010
    Yes you can gey code for it what make off car is it?
    Problem Solver:
  • 28 Answers
Www.duhville.com/2008/10/01/diy-unlocking-the-vw-radio-safe-mode/
Posted on Mar 02, 2018
starlet4life
  • 89 Answers
SOURCE: Can't get past 'SAFE' on Phillips radio
Usually you need a dealer to unlock the NEW ones after entering 3 wrong codes but...
http://www.davidsonelectronics.co.uk/code_entry.htm
Posted on Oct 15, 2008
  • 10 Answers
SOURCE: led lights do not work on radio/cd player. no station/time displ
Work in car audio for a living. dodge caravan's are notorious for having there cd player's **** out. if the led display is out the built in reducers for the display power supply are more then likely shot. head to a junk yard and pull one out if you want to keep it stock :)
can prob get it from them for about 20 buck's and it will plug right in were the old one did. or you can go after market head unit (125-900$ at any electronic's store) buy a harness (about 18$) and a mounting kit (25$) for the easyist install :)
hope this helped
Posted on Mar 04, 2009
UpfrontAudio
  • 47 Answers
SOURCE: safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set with the button ''1'', the second number of your code can be set with button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons the value indicated in the screen will be increased by one. So if the first number of your code is 5 then you have to push the button ''1'' 5 times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an actual sticker which is in the format you describe. You'll need to remove the unit from the dashboard to be able to get access to this.
Posted on Apr 20, 2009
SOURCE: Unlock code for acura bose car cd radio for 3.2TL 2000 Model
Oh I had the exact same problem. I have the same year and the code was a 5 or 6 digit number that i found under the circuit box cover in the engine.
Posted on May 21, 2009
SOURCE: display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
Posted on May 30, 2009
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
Battery went flat, now why are radio and mmi not working?
Because the battery went flat. Most likely need a code from the dealership to make the radio work again.
Sep 03, 2015 | 2008 Audi Q7
My bettery went flat on my rover 45 impressions 02 plate now my radio wants a code it just say code wait on the display. can any1 help me plz
Try '0000'. If not, you need to take it to a car audio specialist. I have also read that if you remove the radio and put it in a freezer bag in the freezer for 24 hours, it clears the memory!
Nov 24, 2013 | 2000 Acura TL
Alpine xqd101550lnf not working
Sometimes removing battery will mean the radio has to be re-coded on re-placing the battery.
You may this same situation if your battery went completely flat.
Nov 26, 2017 | Car Audio & Video
I have a 2003 range rover l322 4.4v8 i had to have i towed in after the warter pump failed it was towed in around 13 miles useing the proper operation of puting the transfer box in nutral as show in the...
well its a tow truck back to landrover service centre
sort out the battery charging problem and parasitc draw
out of the battery
and clear the fault codes
Mar 26, 2017 | 2004 Land Rover Range Rover
1998 Jaguar xj8 sport 48000 miles on clock, stood for a while in winter and battery went flat and remote wouldnt work, charged battery up, remote still wouldnt work so changed batteries as recommended in...
the remote may have come un-synchronised. (Due to a heavy knock or interference from a radio transmitter source. Like someones speed radar detector, or when the battery went flat.)
Consult your dealer on the synchronising process. This is an involved process but easy enough to do yourself at home!
Jan 24, 2011 | 1998 Jaguar XJ8L
Car went in to garage and the battery went flat so now need to entre the radio code to get my radio working again its a rover 75 so can you please help me
The radio will have to be removed from the dashboard.
Then post the radio make+model plus all the letters+numbers found on any labels, barcodes or stamped in the metal casing
May 12, 2010 | Car Audio & Video
Battery went flat now wont take key code in drivers door 1994 p38 range rover.did some engine work battery disconected for about a week. when engine work finished.conected batery started fine. went...
key code lock out usually happens when you have entered the wrong code too many times leaving the battery connected should allow the timer to run down for 30 mins so you can try again, it is cumulative though so the more you get it wrong the longer you have to wait. make sure battery is fully charged first.
Jan 30, 2010 | 1994 Land Rover Range Rover County
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
