Heater will not ignite,
The unit will not ignite, the fan comes on and fuel mist comes out the front of the unit. I have gone through the trouble-shooting suggestions in the manual and with no success. the unit has less than 50 hours on it and worked fine when it was stored last Spring. I have not been able to contact CFM Corp as the phone is no longer in service. I also have put clean fuel in it for this season.
  • pbbagley Dec 21, 2008
    Thanks for your time and help. My unit does not have a glo plug or a spark plug. It has a spark wand that sparks across two poles that creates a spark. I will try to clean the fuel nozzles as you suggested. However; as I mentioned, fuel mist comes out the barrel of the unit but it will not ignite. I seems to be more of a spark problem rather than a fuel problem. Any more suggestions if the fuel nozzle or filters are not the issue?
    Thanks Again,
Here is a website that will be very helpful.
a couple of things that will help is to check the filter in the tank clean it will soap and water = remove side cover 5/16 socket and a hand driver or 8mm will work also. take side cover off and you will be able to access the filter. also clean intake filter soap and water. if yours has a spark plug (take top cover off to see and remove.) if so take the spark plug to an auto parts store AUTOZONE they will have it, if not the same brand have them cross reference it. while you have the plug out and your at a parts store pick up some carb cleaner, take the jet out of heater right next to the plug it should have two hoses hooked to it pull them off and the jet has two notches in it twist to line up with holes and pull out it should be a 9/16 and 13/16 wrench sizes to take it apart take oring off then clean with carb cleaner, reinstall all parts fire it up . ps if it has a glow plug a small engine repair shop or lowes or home depot should also carry it = but only replace if it doesnt glow when heater is plugged in. if this doesnt help check out that web site they will show you how to calibrate air pressure and rotor adj. good luck
Posted on Dec 19, 2008
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
I hava an All Pro 65,000 BTU heater. It was working fine a week ago. The igniter glows, fuel mists but doesn't light off then shuts down. Ideas?
I am sure you have confirmed that the fuel is fresh and good, no water in it, etc.--
It is kerosene, not #2 Diesel fuel, right?
And the shutting down is good, if the flame does NOT ignite--- :-)
So we have to figure out why the fuel is not getting hot enough to ignite?
Question-- is the oil spray passing close enough to the ignitor?
And this unit does NOT use SPARK to ignite?, correct? --
for most of these heaters have spark ignition.. I am learning all the time, too!
How about checking the fuel pressure. and the air -- is it correct?
Check with your manual how to check and adjust.
After testing these tings, let us know what you learned
Mack B
Jan 15, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
125btu reddy heater, somene mixed some gas in the heater and now it won't ignite. how to fix??
Drain it clean it out real good clean out the fuel system end to end. From the line in to the tank thru the filter and so on remove the nozzle clean the screen and nozzle put it all back together. with the top section removed try to start the heater. You should have a fine mist of fuel and spark if it lights shut it down and clean the photo electric eye with a soft cloth and windex. make sure the igniter is clean and close to the fuel mist for ignition, put the top on and turn on your heater.
Dec 14, 2010 | Reddy Heater RH125T Kerosene Forced Air...
Heater just hums for a few seconds but will not ignite.The heater has not been running for some time.
When you say the heater hums is the fan turning? Providing the fan is turning remove the top cover on the heater. Turn the heater on and watch the back of the burner area. Do you see any fuel mist coming from the nozzle? Do you see the ignitor sparking or glowing. Providing you see the ignitor working check the air pressure on the back on the unit. Remove the plug on the back of the unit that does not have a hole drilled in it. Insert a gauge into the hole (1/8" pipe thread) The pressure should be 5 to 6 psi. Let me know what you find and I can tell you how to proceed from there.
Jan 02, 2010 | Reddy HEATER RH170T 165,000-BTU PORTABLE...
My reddy heater R50,(50,000btu)when started will
the unit is working exactly as designed , the system is noticing that the unit has not fired so it shuts down so there is not a lot of unburnt fuel everywhere.
try to find out why the unit is not igniting . is the igniter sparking continually
Nov 12, 2009 | Tools & Hardware - Others
Heater turns off leaving lots of smoke and is hard starting
If this is a kerosene heater,the wick is most likely not adjusted up enough,or the wick is contaminated.The fuel could be contaminated also.Remove the old wick and replace it,and refuel it with clean kerosene,after you pour the old out.
Oct 14, 2009 | Heating & Cooling
Kerosene forced-air heater won't start
Rick---A couple of things to check. With the unit off and unplugged, remove the spark plug-(Note-there may be a little setscrew which you have to remove first)----Put the plug wire back on the plug and ground it against the side of the heator and start it just briefly to see if the plug fires----If it does, then again with the unit shut off, remove the nozzle which has a set screw holding it in. The nozzle has 2 rubber lines running to it and leave them on and then start the unit (Note, be aware that in this test and the plug test that when its plugged in, the fan runs, so keep the plug wire and the rubber lines away from the fan) With the nozzle removed, watch very closely to see if a mist comes out of the nozzle after you plug it in. If no mist comes out, then you probably have either an air or fuel problem.---With the spark plug test, if there is no spark at the plug, the easiest way is to install a new plug and if there is still no spark, then the ignitor is probably bad----------On the nozzle test, try taking off the 2 lines on the nozzle, one line goes to the fuel tank and the other line is the air line (take note which line goes where) first blow thru each connection on the nozzle to see if its plugged and if its not then blow thru the hose going to the tank and you should hear a bubbling noise in the tank--if not then, its plugged or the hose is split----------The other line is the air line and if you can't get anything on it, the filter may be very dirty----behind the filter, there should be a port for checking the air pressure when the unit is running----The unit I have runs on 3 psi pressure, BUT yours may run on a different setting--That psi setting may be stamped on the unit behind the filter---Hope this helps
Nov 10, 2007 | Heating & Cooling
Heating & Cooling Logo
158 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
