i need to know how to configure a Linksys router ,, i have a westell 6100 modem .. i m subscriber for verizon dsl
=== the o.s is windows vista === i want to connect my note book wirelessly == i have two computer one is desktop and one laptop == i m able to go online line when i connect the modem but i want to connect the LINKSYS 4 prot router == plz help
Your modem will need an RJ11 or RJ45 connector on the back, which should be connected to your router via a relevant cable.
To get into you routers settings, you will need to type it's IP address in your internet browser(eg 192.168.1.1) or similair.
When in the settings look for DHCP settings and enable DHCP so as the router can allocate your pc's an automatic IP address.
The modem should already have it's settings and distribute the connection via your router.
Make sure you enable wireless also, but once you have it running make sure it is atleast WEP secured, this you will find in the security settings, you will need set the pc's also with the same encryption numbers that the router gives you or they will not connect.
Go to each of your pc's network cards in Control panel>Network Connections and right click to properties.
On the TCP/IP line highlight it and click properties and ensure obtain ip address is ticked and click ok.
Make sure also that you use the connection and file sharing wizard to set up your pc's to share files if required.
Lastly, i would of recommended purchasing a adsl modem/router as it's all built in one unit and easier to set up and troubleshoot when a problem occurs.
Was this helpful?
Yes
No
Popular Solutions for Encore ENAFN-RT514-PR Router
I Have 4 computers connected to a d1-604 router and can only connect to the service with one they...
(More)
I Have 4 computers connected to a d1-604 router and can only connect to the service with one they all worked at one time. I have avg virus protection on 3 computers and I have just instaled Avast on the other. The one that works has avg protection. I have Contacted my provider and they checked the conection and think it might be the Firewall in the Router.
I just purchased the above router and wild blue satellite internert is not listed under the isp...
(More)
I just purchased the above router and wild blue satellite internert is not listed under the isp address. What should I do? or is this router not compatible
Hi I am using the SohoENAFN-RT514-PR router for 3 years without any problem but all of a sudden, I...
(More)
Hi I am using the SohoENAFN-RT514-PR router for 3 years without any problem but all of a sudden, I cannot access my own program http://www.alldownlineclub.com which is hosted by LowCost Webspace. Any program hosted by them, IP 72.55.137.164 is blocked. When I by-pass the router, everything is ok, it seems the router is blocking this IP, how can I correct this? I did reset the router with no result. Thanks in advance, Mike mjm2@videotron.ca
