Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC210C Pinter/Scanner/Fax message reads ''cover is open''
Hi. ''Cover is open'' message appears on the printing dialog box on computer screen, but no messages are appearing in the little window on the printer/scanner/fax machine. Scanner cover and main cover seem to be closed. The printer starts up only when it is initially plugged into the wall, the scanner light comes on and it makes a few carriage adjustment noises, but no message. On/off button doesn't seem to do anything; only starts up when outlet plug is used. What do you think? Thanks.
5 Suggested Answers
  • 9 Answers
SOURCE: borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Posted on Nov 19, 2008
  • 50 Answers
SOURCE: cannot receive fax with MFC210C using windows XP or otherwise
Check the receive settings. Make sure it is set to the fax setting. Make sure it is NOT set for destinctive ring.
Posted on Oct 09, 2009
SOURCE: Brother (photocopier, fax and scanner machine)
I have fixed this problem on my 7820n printer by brother.
open the back door, then inside there will be a black colored other kind of like door that pulls back away from the roller. on this inner door is a black long thin plastic lever that runs from about the center of the inner door to the right. on the right end of it is a lever that slides along a curved increase on the right side wall. when both doors are closed this right end of the rod or lever moves up to close the gap between what is the sensor. this long thin plastic rod had snapped out of place and when i snapped it back in making sure the spring was correctly installed on the left end of it and the middle part of the rod slid correctly in its groove...the right end of the lever correctly closed the gap on the sensor (when both doors are closed) and the back door open error went away.
So that's how you really fix it!!!!
James Hilliard - Totally super awesome guy! hee hee
Posted on Feb 12, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: how to recieve a fax threw brother MFC210C
Unlike many all-in-one units, this one can be used as a stand-alone fax machine, not requiring you to use fax software in your computer. Make sure you have a telephone line connected to the LINE jack on the side of the machine, and that you have gone through the fax setup steps in the manual. You can download the manual and a quick setup guide from Brother here if you need a copy. Once the machine is set up and on a phone line, receiving a fax is automatic when someone calls in.
If you are having some specific problem setting up your printer or something is going wrong when it's trying to send or receive a fax, please post a follow-up comment with more detail about the trouble. I'll try to help further if you need it.
Posted on Mar 08, 2011
Solution for unable to Init.43 repair
To clear the message, you need to disconnect the Brother machine from the power outlet to check the machine. Follow the steps listed below: Check for foreign objects, such as a paper clip or scrap of paper, inside the machine. Disconnect the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. If the error continues to appear, move the print head and examine under the print head. NOTE : The images shown below are from the representative product and may differ from your Brother machine. 2-1.Disconnect the Brother machine from the poweroutlet. 2-2.Open the scanner cover by pulling up on the lower right corner of the cover. 2-3.Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area. 2-4.Gently move the print head to the center. Caution Be careful not to force the print head to move. If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us". 2-5.Examine under the print head. If anything is found, remove it. Hint Use a flashlight if necessary to check thoroughly. 2-6.Close the cover and reconnect the machine to the power outlet. If the message continues to appear on the LCD, the machine will require repair as the print head has failed and will need to be replaced.
May 29, 2014 | Brother Sealed Mfc-j430w Wireless Printer...
Dcp 7055 brother printer in error - print unable ec
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Note
    In order to transfer data from your fax machine to another, you must have the station ID programmed in your fax machine.
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set.
  4. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Start.
Step2: Verify and Transfer faxes in memory
Step3: Reset the machine After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, do the following based on your country:
<USA>If your unit is still within warranty, try to locate a Brother Authorized Service Center in your area or google to obtain contact information for the appropriate Brother Customer Service Center.
If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
Aug 04, 2013 | Office Equipment & Supplies
How To Repair Error " Print Unable 4F" in Brother MFC-J415W
Sir/Madam
I suggest You Perform Below mention steps To Fix Your brother Printer Issue,
Step1: To clear the message follow the steps listed below:
  1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
    Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
NOTE: The images shown below are from the representative product and may differ from your Brother machine,but their inner structures are same.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover.
3-3.Check the print head's position.
If the print head is on the left side, go to step 3-4.
If the print head is on the right side, go to step 3-7.
If you can not find the print head, go to step 3-8.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it. 1b555a0b-2eb3-488c-883c-4c7db77f04ff.gif
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
3-7.If the print head is on the right side.
The print head is positioned at the far right hand side, you cannot move it. The machine has a mechanical malfunction and will require repair.
3-8.If you can not find the print head.
Step2: Check if the machine has faxes in its memory
Note
1.Transfer the Fax Journal Report
Press Menu/Set or Menu on the Control Panel of the machine.
Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If your question was not answered, please check...
How do clear the message Unable to Unable to Chang Brother
Or
If you still need Brother Printer Help Then Follow Us On:
Brother Printer Support
Dec 19, 2012 | Brother Ink for Mfc J415w Printer
SAYS UNABLE TO CLEAN
"How do I clear the message Unable to..." ( "Unable to Change" "Unable to Clean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3-2.Open the scanner cover by pulling up on the lower right corner of the cover.
3-5.Examine under the print head. If anything is found, remove it.Use a flashlight if necessary to check thoroughly.
1.Press Menu/Set or Menu on the Control Panel of the machine.
2.Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
3.Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
4.Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
5.The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
4.Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
5.If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
Feb 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
1.
2. If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine...
Thanks.
Dec 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean messgae
1.
Thanks.
Printer will not print
  2. User's manual:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=5&flang=English&dlid=
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to initialize
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
LEXMARK ALL-IN-ONE PRINTER X5250
YOU RUINED IT, REPLACE THE PRONTER.
Jun 20, 2017 | Brother HL 1260e Laser Printer
Brother MFC 210C All-In-One InkJet Printer Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
