Question about Kenwood eXcelon KDC-X879 CD Player
Unit only has power for a few seconds
The faceplate stays open and when I try to turn it on the unit lights up, adjusts back and forth and then turns off within 3-5 seconds. Cannot get the unit to stay on. KDC-X879
  • manuelinares May 03, 2009
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Posted on Feb 03, 2009
When unit turns on, the unit will come on for few seconds and then shut off for few seconds. back and forth like that continuously. what to do?
May be a faulty thermostat. Try bypassing the t-stat, if the unit keeps running normally, the stat is bad.
Feb 17, 2015 | Heating & Cooling
DVD Player Won't TUrn
If the unit does not see the door switch (the door where the disks are inserted) it will power off after a few seconds. Under the door there is an adjustment for the door switch. It's about an inch back from the front face of the unit and - this is tricky - it's behind a small plastic cover. If you push with your finger you will feel a soft spot and will see the edges of plastic. The plastic piece is about a quarter inch high and less than an inch long. After removing the plastic cover you'll see the adjustment screw. Loosen the screw a little bit and you'll be able to slide the screw (which is attached to the switch). You won't see the switch, but sliding the screw left or right (it's in an oblong hole) will adjust the switch position. Change the position until the unit powers up and stays on.
Jul 18, 2009 | Sony DVP-CX995V Multi-disc DVD Player
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
Replaced lamp in optoma ep1690 but there is not projection
Hello, many of times this is related to the brighter being turned down and we go about trying to turn up the unit thru the remote and you may need to do this adjustment directly from the panel on the unit.
If this should fail, you may need to unplug the unit and allow it to be off for over 24 hours and this will cause the unit memory to return back to the manufacture's settings and if you still get the same result, consider your lamp may have played out, need to be replace... good luck and I hope thi helps.
Jan 23, 2009 | Televison & Video
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Garmin StreetPilot c340 stop responding no sound, no movement at all - DEAD! Serial #116484764 Registration Code VADUCBQ
please leave the unit with out power for few hours and then again start the unit.
that may help you in some cases
Aug 12, 2008 | Garmin GPS
Faceplate not working
Try disconnecting the unit completely.
Nov 09, 2007 | Sony CDX-F7700 CD Player
Philips 42FD9954
Hey I have the same problem with my 42fd9954/69s. The best solution that I found that works everytime is I have taken the back off my plasma hung it on the wall. Then when I need to turn it on I it starts clicking, so I get my $10 room heater and blow some hot air down the back of the tv from the top and 30 secs later the tv will turn on.
Too easy. Bit dodgy, but I am a uni student!
Nov 08, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Illumination not working when faceplate is open.
Wire braid out to the faceplate has got a parcially broken wire on it. Sony referes to it as a flexible circuit board. Part can be purchased from sony directly, an on a one to 10 scale to replace about a five.But it does involve taking your radio apart. So if you are handy at electronics. you can look it over. If you have doubts let a professional do it.
Jan 05, 2007 | Sony CDX-M8815X CD Player
Kenwood eXcelon KDC-X879 CD Player Logo
199 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
