Canon Np-3030/3050/npg-5 1376a003aa Logo
Posted on Aug 11, 2012
Replace cleaning web. call service rep - Canon Np-3030/3050/npg-5 1376a003aa
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
366
Points
9
Be awesome. call service rep
I need to know what electrostatic filter to get for a mortex 96-894w-0p a-coil inbetween the channels measures 16x18
First, I'm not a Mortex representative.
* Call your local HVAC Vendor for support.
* Contact ; http://mortx.com/contact-us/
*** The following is for information only.***
* Mortex 96-97-98 specs; http://www.raganassoc.com/wp-content/uploads/2014/12/MORTEX.pdf
* Additional info; https://www.north-carolina-library.com/pdf/96-97-98-uncased-m-h-downflow-a-coil-series-4c2fe.pdf
* Please note that commercial PRO's will always replace units or components with NEW parts. (Liability and insurance purposes)
* Pro Repair of coil; https://www.youtube.com/watch?v=gOaqXRpqbv8
* Installing Piston metering; https://www.youtube.com/watch?v=1pIikqCS7ao
* HVAC Install: Heil N4H336 and Coil; https://www.youtube.com/watch?v=0DXC-KofWIo
* HVAC Training ; https://www.youtube.com/watch?v=27uCRQ3B8r4
Aloha, ukboy57
*** The following is NOT recommended (but shown to see what's involved in recycled existing parts):***
* Service Rep Coil serviced; https://www.youtube.com/watch?v=iPJLQZhuuxQ
* Service Rep Coil review of previous repair (and following failure); https://www.youtube.com/watch?v=T3blFMAkM1k
* Service Rep Part 3 of coil service; https://www.youtube.com/watch?v=dI0k8goGBVw
* DIY cleaning of coil; https://www.youtube.com/watch?v=ea8ksj6yTN4
Need to replace image transfer belt unit. call your tech rep
If you have a quick service manual it will help you easily. However you can check its manual in the web site.
E005 error
The cleaning Web for the fuser has exceeded its acceptable life counter. The web needs replaced and the counter reset in service mode.
Cleaning Roller Part Number- FA3-8908-000
After replacement, be sure to reset the cleaning web counter in service mode under.
COPIER>COUNTER>MISC>FIX-WEB
To access service mode press the asterisk ( * ) the number 2 and 8 at the same time, then the asterisk ( * ) again.
7helpful
2answers
How to reset eoo5
press*28* to enter service mode select copier>counter>misc/fix web then press cancel button this will clear cleaning web count you do need to replace the web as it has run out hence the error code good luck
1helpful
2answers
A blue and red vertical line appears on the right side of the screen about 18 inches in. It is seen more easily on light colored pictures. Are these dead pixels? Is it repairable. The LG customer...
The service rep is correct. This will either be a poor contact on the flexible cable connector to that area of the screen, but unfortunately almost 95% of the time this is caused by a faulty screen & would need to be replaced by the service centre.
2helpful
2answers
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
2answers
PHASER 7700 ERROR 30
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
Web cam problem
Use the sales toll free number on the Logitech web site. Tech assistance number was not working correctly yesterday, Feb.7. I called the toll free and a nice sales rep. connected me to customer service/tech support.
old marine
old marine
ZJ Limited
ZJ Limited
