Question about Ovens
Reinstall oven switch WB22X5100
Need to know what wires go on what terminals for oven switch WB22X5100 for GE jsp27*j1ad please
SOURCE: replace upper grill element in a old GE wall oven
Replaced selector switch...problem solved.
Posted on Dec 05, 2008
WRMtech
  • 70 Answers
SOURCE: i need to put new terminal block in oven so need to know where
keep all the L1 & L2 leads to the outside terminals and only the N wires go in the middle.
Posted on Feb 21, 2009
jandj_web
  • 3 Answers
SOURCE: Replacing ERC on GE oven
I ran into the same problem replacing my new part. The instructions indicated that the GROUND wasn't used. The Nuetral was located in near the same position. The L1B went to the little black box near the vacant L1B location on the board
Posted on Dec 01, 2009
barkencoa
  • 3463 Answers
SOURCE: WHERE THE WIRING TERMINAL BLOCK IS
The terminal block is always at the rear of the oven.
There should be a removeable cover, which will expose the terminal block.
It may be screwed on, or a lift up plastic cover, but it will be there.
Posted on Jan 28, 2010
SOURCE: I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
How do I replace the door jamb switch on a GE Profile oven?
should be able accsses it by removing side panel on oven may also find the wires and terminals burnt on the switch
Nov 13, 2013 | GE Ovens
This is a repost per instructions from FixYa I would prefer to hear from heatman101 on this please.We just reinstalled a used GE JTP13GV wall oven that was working when it was removed. Everything...
So you have voltage at the incoming side of both elements - good. If you have tested the element with an ohm meter across both terminals with both wires disconnected and have a reading of 1067 ohms you have a porblem. On a 240 volt system as an example with a 2000 watt element the resistance of the element should be 29 ohms. 1067 ohms means there a very slight circuit but when power is applied it simply will not work.
Just try that test again with the wires off the elements. It should not be over 100 ohms. If it is the elements are faulty.
Also with a voltmeter test across the terminals of the elements with wiring connected and the oven elements turned on. If you have full supply voltage across the terminals it definetely means that the elements are faulty as the full supply voltage represents a good active and neutral path.
If you test again and the continuity/resistance of the elements is good then the power isn't returning to the main neutral terminal which means that you have a faulty neutral. Sometimes the thermal cut-off switch has the neutral wired through it. With the whole of the system turned on and the wiring accessible you can use the voltmeter to trace the voltage path from the oven switch, through the elements and back to the neutral.
Feb 09, 2011 | Ovens
How to change the bake element in a GE stove
Unplug or turn off all power to the oven. With most ovens you can then unscrew the element from inside the cabinet with either a screwdriver or a 1/4 nut driver. carefully pull the element out with the wires attached and dont let the wires go back through the holes. Unplug or unscrew the wires from the old element and plug into or screw onto the new depending on the type of terminal. If it is a push on type terminal make sure the connection is tight, if they are not tight pull the terminal back off and tighten the gap with pliers and recconect. put it back together and you are done. If by chance the wires are not long enough you will need to pull the stove out, remove the back panel and make the connections from the back. Good luck, it is not hard.
Dec 13, 2009 | GE Ovens
Aug 19, 2009 | GE JRP15 Electric Single Oven
I have a GE JKP15WOW1WW. I am replacing the
I have the schematic in my hand,
I just id this last night
L1,AUX1, L1 are the 3 black wires
OVL1,N are the white wires
green is the ground last terminal on right ,if your facing it
OVL2 is the brown white striped wire
Jul 06, 2009 | GE JKP15 Electric Single Oven
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
Hooking up new bake element
shouldnt make a difference your elemnt has only 2 terminals 1 wire to each
Mar 19, 2008 | GE JRS06SKSS Electric Single Oven
Ovens Logo
203 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
