Question about Hussmann HUS-LBN8 Self Contained Frozen Food Horizontal Merchandiser 115V 9563
My 8 ft Hussmann freezer is working, but not cold at all
My repairman said the free-on is leaking frpm the walls. He said because it is over 25 yrs old, it needs a new one. Would you please tell me how to fix it? Secondly, would you tell me your licensed repairmen in Toronto, Ontario, Canada so that I can contact them? Thanks.
  • 30 Answers
Unfortunatly, your repairman is correct. The evaporator section (part that makes things cold) of this case is build into the wall and if it is leaking it is not repairable.
Posted on Apr 29, 2009
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
New freezer but loud and cycles every 25 minutes
check that the door seals are a good fit all round,sounds like an air leak.....
May 20, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Brand new upright the back wall of freezer has a
i have filled polythene bags with paper scunched up inside.to fill any empy drawers this will stop all the cold air escaping and being replaced with warm damp air.....works for me.....
Feb 01, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The freezer isn't gettting cold enough to freeze solid and the ice maker isn't making ice because of that too. Repairman says we have a freon leak. Is that a valid response...
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Amana SXD524VW Side by Side Refrigerator
I have a hussmann g6f-8u and can't stop the ice from forming. what should the defrost be set on?
Most all freezers are set at a defrost of every 6 hours (4 times a day) and for about 25 to 30 minutes. This is a good starting point.
Be sure that the system is working right. If you are icing up, you may have other issues.
Hope this helps.
Sep 11, 2009 | Hussmann Freezers
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fifth wheel A/C PROB
Most probably your unit has no more refrigerant charge. Being unused for 8 yrs will cause leaks on seals.Locate for the system sight glass, run your a/c,if you don't notice any bubbles nor liquid appear on the sight glass your unit runs out of refrigerant.Hope some of this information helps you.
Sep 11, 2008 | Dometic Rooftop RV Air Conditioner
My refrigerator is not getting cold
You should try to clean the coils under the fridge . Thats a simple thing to try .If your fridge /freezer cant remove the heat it wont cool ,also please make sure your doors are closing tight. We can start on all the free things you can try first..
Jul 11, 2008 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Hussmann HUS-LBN8 Self Contained Frozen Food Horizontal Merchandiser 115V 9563 Logo
248 people viewed this question
Top Hussmann Refrigerators Experts
Dennis Boxerman
kfinlay1969
Level 1 Expert
Markus Maritz
Level 1 Expert
Are you a Hussmann Refrigerator Expert? Answer questions, earn points and help others
