Question about Vivitar ViviCam 3632 Digital Camera
Card error Unable to format sd card for vivatar 3632
    Genius:
  • 1,199 Answers
Try another brand of SD card! also make sure the lock switch on the card is off!
Posted on Dec 17, 2008
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
I can not formate my SD memory card it shows windows was unable to formate
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
Dec 21, 2013 | Electronics - Others
I have a sd, 4gb kingston memory card, and when i put it in my camera the camera comes up with "card erro" i go to format card and it does nothing. what do i do
Welcome to FixYa.
I just want to verify the model number of your camera is Vivicam3632 because I'm not be able to see that model for Vivitar digital camera, however there where three reasons why do you receive an error message "card error".
First reason is possible that memory card is not yet formatted for use in the camera, but since, you said that you already formatted the memory card, lets move to the second reason.
Second reason is memory card requires cleaning. You can clean it using soft and dry cloth and after you cleane it, try to format the memory card again. you can also used a clean pencil eraser in cleaning the memory card but please be careful in doing this. You just have to rub it slightly to removed the dirt.
If you still have the same error after doing those two steps, You need to replace the memory car.
"Card error" is also possible of camera malfunction. In this case you have to contact your service center.
Feel free to send us comments or suggestions if this solution was helpful.
Thank you for using FixYa.
Apr 07, 2011 | Vivitar ViviCam 3632 Digital Camera
LG Ally Android phone says it's checking the SD card for errors. Can't access SD card.
you can try plugging the SD card into your computer with an SD card adapter and see if you can access your files.
You may have to format your SD card if you cannot access your files this way. from the phone go to settings, SD Card - phone storage (some phones its labeled different) From there you can format your SD card, depending on your phone you may have to choose Unmount SD card first.
If you continue to receive errors or are unable to format the card, it is most likely that the SD card is bad and needs to be replaced.
Mar 21, 2011 | LG Ally Cell Phone
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Unable to use card
Firstly, what size memory hard do you have? Is it an SDHC? Secondly, have you checked that the memory card isn't locked (there is a switch on the side of it). Has it worked with other memory cards?
May 07, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
Card will not format
memory card? and SD card? whatever the card hook your camera to a usb to computer and find it under "my computer"
look at all your drives you should have like c, d , e, f, g, h, select the last drive and see if it finds your card if so try formatting it through the computer, whatever you do dont select c or d to format. if problem persists buy a new SD. I find good deals on ebay or Walmart.
Dec 23, 2007 | Samsung S850 Digital Camera
Vivitar ViviCam 3632 Digital Camera Logo
Top Vivitar Cameras Experts
Steve
Computer Links
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
