Question about Philips 32PT81S 32" TV
Component video has sound but no picture
I am hooking up my ps2 to the component video on my philips 32pt81s. It is hooked up correctly, but what it says in the manual is that you need to go to an onscreen menu and change the AV1 input to CVI input, I have tried doing step by step what it says in the manual, but there is not an option to switch between the 2 inputs. Any suggestions???? I am racking my brain over this!!! I hope i have included all info needed to help, if not please ask me questions, this will be a HUGE help
techman
  • 3130 Answers
SOURCE: Component Inputs Dont Work Equally
Are these the scart plugs your talking about? If it states by the input its for 480i and the other one says its for the 1080i and the 480p then theres no other way to switch it as the manufacturer went cheap with the inputs by not putting in a switching slector circuit. Sorry. good luck
Posted on Aug 25, 2006
  • 3 Answers
SOURCE: hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Posted on Jan 04, 2008
tvtek
  • 1284 Answers
SOURCE: CVI connection
On a Philips TV the only way I know to switch to any of the inputs is by scanning using channel up or down. This model is capabable of 480P input only at the CVI/Component input. This is not a HD television. It is only a EDTV (enhanced definition) if you try and input anything iver 480P IE: 720p or 1080i, the double image and/or lines is what you will get.
Posted on May 28, 2008
SOURCE: Hi -I have a Philip
turn to channel 2, push the channel down button 'till you get to either FRONT or AV
Posted on Jan 05, 2009
AJIN G
  • 6694 Answers
SOURCE: Philips 30PW850H 30" TV screen is completely
hi,
normally color crt tvs have three guns such as red green and blue. when the voltage at the cathode any of these guns go to zero that color will lead in the screen.
in ur case the green cathode voltage is low. that's why the is green on all over the screen.
if it suddenly came then there is a possibility of dry soldering in the pcb behind the picture tubes neck. we called it as base board. which consist of three transistor or one ic for cotrolling cathode voltage of the guns .
if u have a soldering iron the open ur tv and try to re-solder components in the base board. mainly the component with three leg ( if transistor). if there is ic it will have more than 6 legs . if you can try to re-solder all the points. Be care-full that dot make short circuit when soldering. after care full soldering power on the tv and watch the scree. you problem Will solved.
if u need any further assistance from me, feel free to contact me through fixya.
ok
Posted on Jan 16, 2011
I hooked up my Vizio LED LCD to my Philips surround sound and my DVD picture is pink. What do I do?
This sounds like a problem with the component video connection (the red/green/blue cable; sometimes labeled Y,Pb,Pr). You can get a pink screen if the Green (Y) or the Blue (Pb) aren't plugged in correctly. Recheck those first.
Mar 01, 2011 | Philips CCC130AT 13 in. TV/VCR Combo
How do i hook up the ps2 and wii
Assuming you have your cable or satellite hooked up to a component in, you can hook up either the Wii or PS2 to the other component input. The other will have to hooked up to the S-video input or composite. (Personally, I'd hook up the PS2 to a component in and the Wii to S-video as the Wii is only a standard definition game platform anyway.) Good luck.
Dec 25, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sound but no picture on PS3 using AV3/4
the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
Apr 05, 2009 | Philips Televison & Video
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Bose lifestyle v20 sound but no video
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Sep 26, 2008 | Bose Lifestyle V20 System - black Theater...
No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Jun 30, 2008 | Yamaha HTR-5930 Receiver
No video - blue screen...
since you bought this console used, it maybe set to HDMI 1080p/ 1080i/720p output(by the original owner) and if your TV does not support this there will be no picture, the only way to lower the output resoloution is to get into the options menu but to do that you will need a freind with a tv that supports whatever resoloution its been set too.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
DVD and PS2 in Black and White
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Hooking up PS2 to Component hookups on 37" LG LCD
make sure the input is turned on in the menu. Sometimes they get locked out.
Dec 30, 2007 | LG 37LP1D 37 in. LCD Television
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Philips 32PT81S 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
