Question about JVC Video Cameras
Won't run on batteries
The camera will operate on dc charger,but when batteries are in no power.I have purchased a new battery but will still not operate?
    Master:
  • 638 Answers
The connectivity with the battery terminal is a problem .open n check there may be some loose connection on the points where ur battery inlets supply connection on the main board of ur camera.
Posted on Dec 17, 2008
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Can I plug a camera, shaver, or cordless tool battery charger into this Modified sine wave
Yes you can and no it won't harm it unless something is wrong with it or the charger.
The inverter output doesn't get to the battery, just the chargers output.
Aug 26, 2012 | PowerBright Power Bright 2300 Watt Power...
My name is Satheesbabu. I have a Canon Video camera MV 800i,purchased 6 years back. I lost the power chord. It is written on the camera 7.4V in one place and 8.4V at the power connection point. Please...
there are several power cords on ebay for your camera as well as new batteries if you need one. Do an ebay search for MV 800 charger, here is an example of one I found. http://cgi.ebay.com/Desktop-Charger-Canon-MV800i-Camcorder-/380317041118?pt=Batteries_Chargers&hash=item588ca981de#ht_3278wt_1141
Mar 04, 2011 | Canon Video Cameras
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Jun 13, 2010 | Cameras
Camera acts dead. Hasn't been used for a long time. Will not turn on. anti-ground swithch is in start/stop mode. replaced 3 volt lithium battery. nothing operates. battery in or out, charger in or...
I need exact model number of your Sony camcorder to find out reason of no power up problem.
Please check charger output volts with multimeter as it should be equal to written on back of charger, approx 10V DC
Thanks.
Mar 27, 2010 | Sony Handycam DCR-TRV310 Digital Camcorder
WILL NOT OPERATE ON BATTERY, BATTERY TESTED GOOD
Please try the following things :
1. check the battery contacts for dirt or rust and these are contacts both on the battery and on the camera. clean with solvent or file to remove the dirt or rust.
2.check that you have removed the charger DC cord from the camera before using the battery.This has happened in a few cases.
3. get some solvent e.g ethanol, spirit etc and drop it into the hole where the DC cable from the charger enters the camera. plug the DC cable into the hole in and out rapidly and several times to clean the contacts.
If the above measures fail, take it to the repairman.
Oct 08, 2009 | JVC Video Cameras
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
No power at battery and camera can not start up,battery does not charge up in charger
yea ive got the same problem
mine powers up on dc but have brought 2 new batteries and it does not power up took into local shaop they charged the bateeries still wont power up on battery
Nov 27, 2007 | Cameras
Video Cameras Logo
46 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
