Voip phone is workin properly but when i try to send fax it shows comm error
  • 4 Answers
Make sure the same dial tone you can talk on is plugged into your fax machine. Try plugging a plain old telephone into the wall jack your fax is plugged into. Until you hear dialtone in that jack, don't bother troubleshooting the fax any more.
Posted on Dec 18, 2008
Sending fax displays comm.error
There are many things that can interfere with proper sending of faxes. Has anything changed in your office recently? Phones changed? Did you recently get DSL service from your phone provider? If so, you probably need a DSL filter on the line going to your fax machine. Try faxing to different faxes to make sure that it is not the person you are sending to that has the problem. If you are using Voice Over IP or VOIP phone, good luck, as older fax modems do not always play nice and you will likley need to speak with your VOIP provider to ensure they have their lines configured. If nothing has changed in your office then perhaps your modem has just failed, it does happen. A new cord between the jack and the machine is a a cheap test as well. If you have a telephone, unplug the fax and plug in the phone and see if you can make a call.
Sep 04, 2014 | HP LaserJet 2840 All-In-One Printer
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
When sending fax on canon pixma MX350 i get a NG error REPORT what does this mean
Hi There!
Comm Error will show on the display if there is an issue with the phone line like an interference or it's not connected directly to the wall jack.
What you can do is check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then press start.
Hope this helps.
Vikroks
Mar 29, 2011 | Brother IntelliFAX 560 Plain Paper Fax
I cant send faxes over voip with the hp laserjet 3050 fax machine....really at a loss of what to do keep getting comm errors.....receiving faxes just fine
I found a blog on the Ooma site that said this can be fixed by prefixing your fax send number with 99. There were several comments from people who tired this fix and it worked for them!
Nov 23, 2009 | HP LaserJet 3050 All-In-One Printer
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
Have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Hp j6400 fax over voip line error code 388
Fax machines are ANALOG devices, VOIP, Vonage etc are DIGITAL devices.. It won't work reliably
Oct 29, 2008 | Office Equipment & Supplies
Comm error 232 & no fax detected when receiving
Sam here. Anyone have a solution?? We use a voip setup for phones. Wondering if its related. We have signal converter boxes installed.
Oct 21, 2008 | HP LaserJet 3055 All-In-One Printer
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
